Results 1 to 17 of 17
    Veteran Member Four Rings jackyaudi's Avatar
    Jun 26 2007
    '02 A4 1.8TQS
    Montreal
    Auto-leveling headlight error
    I am getting that annoying Auto-Leveling error on my dashboard after swapping the Xenons with stock headlights and putting them back on my car.
    My Xenons dont re-adjust anymore (going up/down) when I turn them ON.
    Anyone knows where is that sensor and/or how to check it??? I made sure all connections are fine, still nothing.
    I think its not just a matter of erasing the error code, but something with the sensor.
    Thanks.
    For your OEM HID D1S/D2S/D3S and HID conversion [Headlights/Foglights], and Interior/Exterior LED needs, send me a PM.
    Stuff F.S: http://www.audizine.com/classifieds/...4-parts&cat=21
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    Re: Auto-leveling headlight error
    IIRC, if you have lowered your car then the front autolevel sensor is too low.
    You will have to raise the front of the car up about 3 inches and then you can erase the code.
    Jun 26 2007
    '02 A4 1.8TQS
    Montreal
    ^^ Did not lower it at ALL. Just put it on ramps, swapped them, swapped them back, got error on both Xenons and halogen headlights.
    Jun 11 2005
    Vancouver, BC
    Did you use the VAG to clear the code?
    Bklyn
    I got the same error code when I had some bodywork done. The headlight was removed (and by removed I mean unplugged) and replaced properly by the shop. It needed to be reset by the dealer or by the shop. It was done and I was on my way. Yes, the code needs to be reset when the headlight is unplugged.
    Veteran Member Three Rings PCYC's Avatar
    Sep 07 2007
    04 A4 3.0 6spd, 06 A6
    Atlanta GA
    i removed the negitive batt terminal and i never get errors when removing lights
    Bklyn
    Yeah, I don't think it matters. Mine did the same as yours, lights came on without adjusting. I reset the code and it was fine. I'd start there and look for more serious problems if that doesn't work.
    Jun 26 2007
    '02 A4 1.8TQS
    Montreal
    ^^ so if you reset the code, the lights will start re-adjusting just fine?
    Sep 07 2007
    Atlanta GA
    this happens to me every once in a while
    Jun 26 2007
    '02 A4 1.8TQS
    Montreal
    Removing Fuse #10 will get rid of it until I VAG it later on. I dont want to pay the stupid dealer $100 bucks to clear me a code. Pizdiet.
    Senior Member Two Rings 1fata4's Avatar
    Jan 27 2008
    B6 A4 1.8T
    Tulsa, Ok
    ever since I lowered my car it does that I hate it!
    The Audi is a panty dropper
    Veteran Member Four Rings JMRQuattro's Avatar
    Jul 04 2008
    Seattle, Washington
    My car is lowered 2.5 inches and my lights auto level and it doesn't give me any errors or anything.
    Jun 11 2005
    Vancouver, BC
    If you remove/replace the xenons and power up the car the ECU will detect that the autolevel mechanism in the headlight is not there and deactivate it.
    If your car is lowered too much and try to clear the code and it does not clear that is because the system detects the car is not level or out of its adjustment range so you have to level/raise the car before you can clear the code.
    Disconnecting the battery will not throw the code as you cannot power on the car.
    Finally... anyone with a VAGCOM can clear the code for you so skip going to the dealer.
    Jun 26 2007
    '02 A4 1.8TQS
    Montreal
    ^^ thanks for the explanation! I will take fuse 10 out till I VAG it somewhere
    Veteran Member Four Rings martini's Avatar
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    a4mods.com Stickers!
    http://www.a4mods.com <-- Thats my website!
    - My vehicle is stock.... I promise -
    - BetaAlphaTau member #4 -
    Veteran Member Four Rings michgo's Avatar
    Oct 21 2007
    Wagon/Variant/Avant A4 B6
    i get this error all the time. nothing too harmful, just do as everyone above said
    I heart wagons.
    'It's actually a pretty big pet peeve of mine when people mess around with my photos', MmmBoost
    shave it mold it sand it paint it
    Aug 26 2005
    The "home" position of the headlight servo motors must be reset in the range controller using VAG-COM. The servo motor position feedback potentiometers, in the replacement housings was at a different value compared to the position feedback value on the housings installed before. When a step change in position value occurs, the range controller can't figure out where the home position is at any more, so that needs to be reestablished in the range controller for the headlights currently installed.
