Results 1 to 12 of 12
    Veteran Member Four Rings bOOOOstedAudi's Avatar
    May 27 2004
    C6 A6 S-line 3.0T Quattro, BT B7 A4 2.0T S-line Quattro
    Sacramento, CA
    I need all you guys to help me out.
    I was driving in traffis on the freeway when all of a sudden I notice I have no brakes. Pedal was ridiculously hard to push and the car has a really rough idle. I need to leave for dubfest tonight and i need you guys to tell me what's up with this. here are the pics[IMG] [/IMG]
    and[IMG] [/IMG]
    May 27 2004
    Sacramento, CA
    bump
    Registered Member Four Rings Zodiak's Avatar
    Washington DC
    wait, did your brakes not work at all? or did you just lose your power brakes (making it very hard to press the pedal, but you were still able to slow the car)? I haven't worked on that side of the engine, but I know the master cylinder is over there, if a brake line cracked or broke then you'd lose brake fluid and use of your brakes. Can you brake with the car in its current state?
    May 27 2004
    Sacramento, CA
    yeah it just make the brakes really hard to press but i check the fluid level and it was fine.
    i heard/felt air coming from it too
    Senior Member Two Rings chaos on wheels's Avatar
    Feb 25 2004
    Fremont
    That looks like the vacuum line to your power brake booster. Power brakes use intake manifold vacuum for the power assist. Your brakes are hard to press because the power assist is gone. And the MASSIVE vacuum leak is causing your rough idle.
    I'd fix it before going anywhere.
    -Jason
    98.5 1.8TQ
    Registered Member Three Rings VtAudi's Avatar
    Feb 12 2004
    00' A4 2.8
    Burlington, Vt
    Just stick a big wad of gum on it, Dubfest... woot
    Registered Member Four Rings audlman's Avatar
    Apr 19 2004
    04 SRT-4
    louisville, ky
    do whatcha gotta do.... maybe.
    Registered Member Four Rings SEXIC─N's Avatar
    May 20 2004
    More cars
    Never Land Ranch
    similar thing happened to my truck, ended up being a leaky master cylinder.
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    AMD/EPL Tial 605 B5 S4 SOLD
    Veteran Member Four Rings white fish's Avatar
    Feb 21 2004
    05 allroad
    T.O.
    I agree with "chaos on wheels"
    Veteran Member Four Rings bitterchild's Avatar
    Feb 16 2004
    audi is chit
    chaos hit it on the head
    concours show prep in the DC metro area
    turbos, rods, pistons, clutches, etc.
    May 27 2004
    Sacramento, CA
    he sure did. now how do i find out why my vacuum isnt sucking enough to hold his together. im guessing its a leak but i can't seem to find out where at all. now i hae it being help together by the zip tie and its working fine except of the loss in boost i am experiencing. worked all the way to dubfest. i won 2 dv valve and some madmat stuff in the raffle. changed the dv but stil acting up.
    May 27 2004
    Sacramento, CA
    Still have yet to find out where the hell this leak is at. now im getting mad
