Results 1 to 6 of 6
Thread: VAG Com
    Senior Member Two Rings fcamargo6thave's Avatar
    Apr 08 2007
    VAG Com
    Can anyone please provide a link to were I can buy one of these guys. I hear they are useful in figuring out which coil packs are blown and also in diagnosing the car if u have any problems...
    Thanks
    Jun 02 2008
    Edmonton, AB Canada
    Re: VAG Com
    http://www.ross-tech.com/ the true vag com (current vag com software version is 805.1)
    or you can go here http://vagcables.ecutool.com/index.asp and get a vag cable knock off that runs on software Version 805.0 only but retains all features.
    Apr 08 2007
    Re: VAG Com
    I would like to buy the better one which of the two do u guys recommend
    Thanks for the reply
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: VAG Com
    If you have a misfire, just pop each coil out individually with the car running. What ever coil doesn't change the cars running is the bad one. Either way just replace all of them and put the leftover good ones in the trunk.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Jun 11 2008
    Williamsport, Pa
    Re: VAG Com
    the 'better' one is the one from rosstech as they make the software to be used by the cable and you can always upgrade to the latest software whereas the cheaper ones arnt allowed to run the new versions of their software (the key for the vagcom software is in the dongle)
    Apr 08 2007
    Re: VAG Com
    Quote Originally Posted by dirtybrd View Post
    Thanks I Will try this
