Results 1 to 10 of 10
Thread: Avant Tails
    Senior Member Three Rings ad03avant's Avatar
    Jun 21 2008
    2003 A4 Avant Quattro
    Olympia, WA
    Avant Tails
    I just knocked a hole in one of my taillights. Now I need to replace it. I like my OEM tails alright, but not sure about prices. Anybody have ideas for non-OEM tail light housings that aren't ricey?
    OEM from http://www.genuinevwaudiparts.com is 106...
    Could I get 2 new cool housings for a little more?
    D
    Andy
    -2003 A4 Avant Quattro
    -APR Stage 2 +, Achtuning Snub, Avic D3, USP Front, S4 blades and bi-xenons, APR stealth, 034 HFC, ASA JH3 18', platinum VMR sport gauge, h-sport sways, ABT springs, Koni sports, Zimmerman sport rotors, Stoptech stage 1
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    Re: Avant Tails
    Stick with the OEM housings.
    Everything else looks bad.
    Veteran Member Three Rings Tomek6's Avatar
    Dec 29 2006
    2005 A4 USP 6spd
    Re: Avant Tails
    Does anyone else make tails for avants? I've seen lots of different LED. non LED lights for the sedan but never an avant. I'm not thinking of changing. I like the OEM tails. Just curious.
    2005 Audi A4 USP 6spd |Revo Chip|TT 225 Injectors|Evo MS Intake w/ modified stock ram air|Samco Hoses|Forge TIP|Forge DV|VMR TP|Custom SS 2.5" Magnaflow Exhaust|ECS Snub Mount|KW V2 Coilovers|Hotchkis S4 Sways|BBS CH's|3.0 C/D, Slotted Rotors|USP Front, Rear Spoiler and Interior Trim|Cupra R Lip|B7 Rear Valance|DTH Sideskirts|Grilles|E-Codes|S4 Mirrors and Door Blades|S/w Boost Guage w/ Podi Steering Column Pod|
    Veteran Member Three Rings cjonesgo's Avatar
    May 22 2007
    02 A4 Avant 1.8t qm, '74 Vespa
    oakland ca
    Re: Avant Tails
    look on ebay there are at least two different ones that i have seen, but they are both pretty hideous. i have seen OEM ones pretty regularly for decent prices though, so look around you may get lucky. also, they are typically sold individually so you may save some $ that way, rather than having to buy a pair.
    [CENTER]02 A4 Avant 1.8tqm Dolphin Gray
    Blackout Grills | S4 Bi-Xenons | 3.0 Brakes | RS4 Rear Swaybar | Bilstein Sport Shocks
    K04 | REVO | TT225 Injectors | Apikol SMIC | 034 HFC |
    Dec 06 2007
    Re: Avant Tails
    -Kirk
    BetaAlphaTau Member #58
    Jun 11 2005
    Vancouver, BC
    Re: Avant Tails
    All aftermarket Avant tail lights look horrible. If there was a set that looked great I'd have them on my car.
    Then I look at the LED issues some of the sedan guys have and I rather change one halogen bulb than have a tail light with one LED not light up. That would drive me insane.
    Dec 06 2007
    Re: Avant Tails
    ^^u know i think the LED tails issues were greatly exaggerated, as long as u run a resistor all is well.
    -Kirk
    Dec 29 2006
    2005 A4 USP 6spd
    Re: Avant Tails
    Yeah you're right. That looks pretty terrible. I was just curious, I've never seen anyone do anything to the avant tails really. The sedan guys are always getting them smoked in all types of different ways. Anyway I still like OEM it looks cleaner and not cheap. Thanks for the info though.
    Jun 21 2008
    Olympia, WA
    Re: Avant Tails
    Your right Winston, all of those tails do look bad. I ordered the OEM housing as much as I hate to spend 100 replacing my OEM housing that was perfectly fine until it had a run in with the corner of my sub box when I could have been modding something else. Anyway, stupid move on my part - but a new one is on the way...
    D
    Andy
    Jun 11 2005
    Vancouver, BC
    Re: Avant Tails
    Try this one... I had a tiny bit of condensation on the inside of my housings.
    Took the passenger side one out, used some alcohol to swish it around and let it evaporate and when I came back there was a nice crack in the lens
    Should have done it the old fashioned way with a hair dryer.
    Had to eat more instant noodles for a couple of weeks.
