Results 1 to 24 of 24
    Established Member Two Rings alxjhn's Avatar
    Jun 14 2008
    2008 Audi A8L, 2011 Q7 TDI
    Pittsburgh
    b5 s4 subframe washers
    i replaced the rear subframe on my s4 but i didn't use the washers for subframe. when i say washers i am talking about those big azz washers that go where the four bolts go on the subframe. the question i have is that "not using those washers will it through off the rear alignment"? The car feels fine but when i change lanes at high speeds it feels like that the back end is loosing control. I can not figure what it is. any ideas??????????
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    Re: b5 s4 subframe washers
    put them in?
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Veteran Member Four Rings skunkoncrunk's Avatar
    Apr 18 2007
    2006 Subaru WRX
    Cali/Colorado
    There's a reason that they are there. Go put them in.
    -Hooked on Meth-
    BOOSTADCT
    -Mike-
    Instagram: @mdundurs
    S4's Video (Watch in 1080p)
    Jun 14 2008
    Pittsburgh
    i'm going too this week
    but would this reallty throw of the rear alignment
    Dec 02 2007
    2020 Ford PIU, 2017 D675R
    DC/MD/(VA)
    I think the washers absorb the rolling momentum of the car during turns/lane changing, without that cushion to absorb its like having a rolling tool chest in your trunk slamming against the sides (throwing your rear weight into the direction that goes straight) while you're turning/changing...
    ...just my thought. Please feel free to correct me if I'm wrong.
    2015 B8 SQ5
    Click Here
    Past
    Jun 14 2008
    Pittsburgh
    let me see i will put them in
    Jun 14 2008
    Pittsburgh
    i put in the washers the car still does the same thing
    SOMEONE HELP
    i am STUMPED
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    bad motor mounts/ tranny mounts/ etc?
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Veteran Member Four Rings Overboostin's Avatar
    Mar 15 2007
    New England
    diff mount?
    the homebrew'd s4
    Jun 14 2008
    Pittsburgh
    the car has new engine mounts and tranny mounts and new snub mount
    Jun 14 2008
    Pittsburgh
    the car sways sometimes when i change lines and when i hit a bump. it feels like that i am in a boat i was also told that the bracket that holds the left engine mount is cracked (the aluminum bracket)
    Senior Member Three Rings lonestar22's Avatar
    Aug 19 2008
    DFW
    you got an alignment after all this correct?
    SGM 330i 6MT/RD PLATE LIGHTS/RES DELETE
    STAGE 1 B5 S4, CAN YOU SAY SLAMMED?
    Jun 14 2008
    Pittsburgh
    i got the alignment done two times already
    Mar 15 2007
    New England
    How's your rear diff mount?
    the homebrew'd s4
    Jun 14 2008
    Pittsburgh
    how do you know a diff mount is bad
    Jun 14 2008
    Pittsburgh
    diff mount is good i checked today
    Jun 14 2008
    Pittsburgh
    i drove my car in the snow couple of days ago. it felt like that the back end of the car was slipping like crazy. it felt like the car wanted to go in a different direction than i was driving. i really need to figure what the heck wrong with this. if any audi mechanics are out there feel free to come over and diagnose the problem. i am located in philadephia, pa
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    I'd say its your suspension. Control arms, tierods? You might have instsalled everything wrong. take it to a shop and have them look it over.
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Jun 14 2008
    Pittsburgh
    the tie rods were installed at a shop. it feels like it is coming from the rear. i was thinking it could be the sway bar links in the rear and could also maybe a wheel bearing. the controls were replaced in the rear. i also did the alignment for the car too after changing the rear subframe. is the DIY for changing the rear subframe?
    Mar 20 2008
    Italy
    Change all the suspension arms bushings.
    I had the same issue on my Rs4, changed all the bushings and it's ok now ;)
    RS4 B5
    Jun 14 2008
    Pittsburgh
    where can i get the bushings for the rear ?
    is there rear tie rods for these cars?
    i will be changing the rear wheel bearing this week.
    i don't think the back tires are flat on the ground
    Jun 14 2008
    Pittsburgh
    it feels like that the back tires aren't sitting properly. i was driving the car in the snow today. the was a lot of noise coming from the back wheels. it felt like the tires weren't touching the ground correctly
    Senior Member Two Rings badbiturbo's Avatar
    Jul 08 2008
    Porsche 996 GT3
    damn, i have to swap my rear subframe too, how long did it take you? This sounds like a swaybar problem to me though
    Sold
    ‘00 S4 // Silver // Alcantara Sport Package // 6mt
    ‘03 996tt // Arctic Silver // Metropol Blue // 6mt
    Current
    ‘04 996 GT3 // Guards Red // Natural Grey
    Jun 14 2008
    Pittsburgh
    the rear subframe took me about 6 hours to change out. where can i go to get the rear subframe aligned at. prefer south bend indiana area
