Results 1 to 4 of 4
    Registered Member Two Rings
    Sep 29 2008
    1.8t b6 5 speed
    pdx
    painting lowers: adhesion promoter before primer?
    Ok i have done alot of search and still cant get it straight. Do i use the plastic adhesive promoter bfore i prime? DO i need to prime it? Thanks for the help!
    02 B6 1.8TQM CURRENT
    97 B5 1.8TQM RIP
    98 B5 1.8TM SOLD
    91 MK2 Jetta (project car)
    Selling a BT set up? gt30? something fast? PM ME!!
    Veteran Member Four Rings rxrep's Avatar
    Feb 28 2006
    has nothing in it but memories.
    Pittsburgh-Philly
    Re: painting lowers: adhesion promoter before primer?
    Adhesion promoter goes direct on plastic. I still prime mine after that just to make sure I didn't miss anything in the prep. Plus, using primer that is not the paint color gives you good indication on if you've gotten all areas evenly with paint.
    My 2004.5 APR Stage 3+ is SOLD
    Sep 29 2008
    1.8t b6 5 speed
    pdx
    ok, i was thinking about using a sandable filler primer to get rid of the plastic texture. I think i will do a DIY tomorrow
    97 B5 1.8TQM RIP
    98 B5 1.8TM SOLD
    Veteran Member Three Rings b5s4tt's Avatar
    Mar 14 2007
    s4
    queens
    bull dog adhesion promoter, and there are many others you can buy. and yes you use it before anything is applied to the plastic
