Results 1 to 4 of 4
    Registered Member Two Rings
    Oct 15 2007
    Audis & BMWs
    SoCal, Taiwan, HK & Penang
    Stage 3 Fueling questions
    Questions regarding injectors: Should I get the ECU custom tuned to run the 440cc injectors ? Can I run the green top injectors with stage 1 program ? For those with upgraded injectors, what do you recommend ?
    MAF questions: Is the RS4 MAF a direct plug and play replacement to the S4 Hitachi's ?
    TIA.
    01.5 S4 TIP (Stage 3-)
    K04s, RS4 mount, 710Ns, Open DPs, Defi HUD, 18" BBS RCs, FK Coilovers, Milltek Cat-Back, AMS/ABT Chip, 22% titanium tint, lip spoiler, E-codes.
    Jun 14 2007
    2000 S4
    Connecticut
    Re: Stage 3 Fueling questions
    The RS4 maf does not work on the hitachi plug NO, its a bosch. I run a RS4 MAF with a hitachi sensor.... VAST as part of their fueling kit custom makes the MAFs to fit in the hitachi sensor.
    Veteran Member Four Rings Tifosi's Avatar
    Apr 27 2004
    Pacific NW
    Quote Originally Posted by changs4 View Post
    TIA.
    RS4 MAF runs on Bosch, so you will have to Bosch via the chart below.
    You will need custom tuning to run bigger injectors to have them scaled properly, just like if you go to a larger MAF.
    Also, you will need RS4 air box (at least the top half) and RS4 accordian hose to fit the RS4 MAF and RS4 MAF housing.
    Active Member Four Rings
    Dec 11 2006
    Boston
    60l# injectors with the corresponding tune is good. Vast and Greg @ SSP do those setups and have great numbers.
