Results 1 to 2 of 2
Thread: Oil leak
    Established Member Two Rings Ghostrider's Avatar
    Jan 31 2007
    86 Alfa GTV6, 91 Toyota HDJ80 Land Cruiser, 2005 Miata, 2020 Miata, and Lexus GX 460
    Charlotte, NC
    Oil leak
    Hy Folks,
    I have a 2.8 30V in my Avant quattro. When the car sits overnight, there is a fair amount of oil that leaks in the front, as in just behind the bumper. Car gets driven for about 10 minutes +/- in stop and go (my commute). When I leave for lunch there is a minor spot of oil 2-3" in diameter. Is this the dreaded oil pan gasket going? I just had the engine replaced (old one overheated and I head one head cracked). When the mechanic installed the new engine (68K), he filled it with synthetic oil.
    Thanks
    Registered Member Two Rings
    Apr 19 2008
    215 PA
    Re: Oil leak
    um i would just jack it up and see what's going on!! its that easy.. if it was a mystery leak and it was leaking in more than one spot all at one time then it is most likely a clogged PCV valve.. but please jack it up and take a gander for yourself before posting!!
