Results 1 to 13 of 13
    Sep 03 2008
    1999 Silverado 4x4, 2001.5 S4
    Joplin, MO
    Coolant leak help (pics)
    I noticed small puddles would form underneath the car so today after I drove the car, I pulled the belly pan and saw some orange crust on 1 of the oil pan bolts on the passenger side but I didn't see any wet coolant. I let the car sit and after about a half hour I still didn't see any coolant. I came back 2 hours later and then saw a coolant drop sitting on the center oil pan bolt that you see in the pictures. I see that there is a little trail coming down the side of the engine block (the flashlight in the picture is pointing at it) but I see no wet coolant anywhere else. I see there is orange crust under the auxilary water pump but I expected that since I see wet coolant down below on the oil pump bolt I would also see some wet coolant under the aux pump.
    Obviously, since there is orange crust under the aux pump, it has been leaking, But could the coolant I see down below be coming from somewhere else?
    It just baffles me that I see the wet coolant trail on the oil pan bolt but I don't see any wet coolant under the aux pump.
    Front to rear photo
    Passenger side looking to driver side
    Flashlight pointing at the block where I see a trail of fluid
    Jun 24 2008
    E46 M3
    Woodinville WA
    Re: Coolant leak help (pics)
    I would suspect the thermostat seal or maybe one of the two hoses that hooks up to the thermostat housing.
    C
    Veteran Member Three Rings drexplode's Avatar
    Jul 19 2007
    2016 M3 - maximum hooligan
    Michigan
    NO freakin way! I had a similar problem on friday.
    My root cause from the audi doctor = hose on the back of the auxilary water pump. My baby should be up and running by Mon/Tues. cost = ~150-200 to fix.
    http://www.audizine.com/forum/showthread.php?t=243839
    Edit - when i opened the over-fill reservoir (hot or cold engine), it literally poured out.
    "A turbo boost gauge the size of a fat spaniels face! - Jeremy Clarkson
    Veteran Member Four Rings 1997gtx's Avatar
    Sep 14 2006
    14 GLI
    Doesn't seem to be a big enough leak to be the aux. pump ... as the others have said, I would think it's likely just a hose going to the pump. Are you losing any significant amount of coolant?
    --Adam
    Have questions? E-mail me.
    Sep 03 2008
    Joplin, MO
    Quote Originally Posted by 1997gtx View Post
    --Adam
    I probably put in about a cup of coolant per week.
    Sep 14 2006
    14 GLI
    Ah -- then that is a bit more than a 'small' leak. I would venture to say it's your aux. pump.
    --Adam
    Sep 03 2008
    Joplin, MO
    I looked again today and I now see the crust under the aux pump is moist. WHere can I get the best deal on the aux pump and where can I get the relocation kit?
    Sep 14 2006
    14 GLI
    ^ Sorry, I can't help you there. Dealership replaced mine and relocated it. PM Daft -- I believe he should have the info you need
    --Adam
    Senior Member Three Rings Muck_and_Grind's Avatar
    Jun 09 2008
    2001.5 Audi S4 (on stands), 1989 Grand Wagoneer, 2007 B9 Tribeca
    Lodi
    i was putting in 4liters a day or more. now the engine is out and waiting for the heads to get done. i hope they weren't warped that bad.
    Senior Member Two Rings readimag's Avatar
    Jun 28 2008
    2000 s4, 2011 acadia, 2010 s4
    Savannah, GA
    damn those are bad leaks mine only leaked under WOT and it was quarter sized after about a month.
    2000 s4
    Established Member Two Rings Longfist86's Avatar
    Nov 01 2008
    08 MkV GTI, 09 Jetta
    Dade county
    check the rear coolant flange. those usually go
    Oct 31 2006
    San Antonio, TX
    ^ What he said. I have the 1.8T B6 and my rear coolant flange is currently leaking.
    Current: 2016 S6 Previous: 2015 A6, 2012 Q7 Prestige SLine, 2005 S4, 2007 Avant 2.0T, 2002 A4 1.8T
    Sep 03 2008
    Joplin, MO
    I'm used to small block chevy's. These motors sure have a lot going on. I just got done pulling and reinstalling the aux pump while leaving the intake manifold in place. (It will definitely be easier and faster the next time I have to do it. For this being the first time it took me about 2 hrs with the longest part being getting the hoses on and off). I took the aux pump apart and noticed the o-ring was bad so I removed the o-ring and siliconed the pump and put it back together. I will be letting the silicone sit for 24 hrs and will be driving the car tomorrow. The leak should now be cured!
