    Veteran Member Four Rings deucescorner's Avatar
    Aug 26 2008
    None
    None
    Oil under intake manifold
    So my friend did my timing belt etc... and tune up.
    He found little oil leak around the valve covers (common) but what I was more concerned to see was some oil right below the intake manifold.
    He decided to clean the TB cause it has a little gunk. As he did that he noticed oil further back, where there was some kind of sensor(was covered in it) and all around that was some kind of oil residue. We hooked it up on the computer and no codes show up, everything came out ok.
    Any ideas what it might be, i'm hoping it's nothing serious
    Apr 18 2007
    ny
    Re: Oil under intake manifold
    Are you using a k&n air filter?
    Aug 26 2008
    None
    None
    Quote Originally Posted by A62TURBO View Post
    no, Mann Air Filter, why?
    Apr 18 2007
    ny
    Because the K&N filter uses oil and sometimes that flows through. When I took off my throttle body to clean it over the summer I looked inside the intake manifold and saw oil so it might be normal.
    Aug 26 2008
    None
    None
    I see.
