Results 1 to 12 of 12
    Veteran Member Four Rings jackyaudi's Avatar
    Jun 26 2007
    '02 A4 1.8TQS
    Montreal
    HID bulb cleaning
    I want to clean my HID bulb, but should I use rubbing alcohol to clean the colored "bar" where the red arrow is pointing to:
    For your OEM HID D1S/D2S/D3S and HID conversion [Headlights/Foglights], and Interior/Exterior LED needs, send me a PM.
    Stuff F.S: http://www.audizine.com/classifieds/...4-parts&cat=21
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: HID bulb cleaning
    Why?
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Veteran Member Three Rings Old No.7's Avatar
    May 27 2007
    1974 Porsche 914
    PNW
    I wouldn't even take a chance touching those bulbs.
    Jun 26 2007
    '02 A4 1.8TQS
    Montreal
    One of the bulbs has some dirt (brownish) on that blue line.
    Veteran Member Four Rings B6driver's Avatar
    Sep 14 2006
    XBOX LIVE GAMER TAG: b6driver
    Eagle Rock, LA, Ca
    HIDs are so dispensable now. if you look on ebay, you can get a whole kit for about $70 (even D1s/D2s for about $50 more) or just bulbs for even cheaper. don't bother cleaning it, it'll probably screw it up.
    2004 A4 1.8 Turbo 5 speed gone...
    2010 Candy White VW CC R-Line
    Veteran Member Four Rings Silverstreak98's Avatar
    Dec 11 2006
    Minnesota
    No, don't clean it.....doesn't matter if there is a little brown spot on it, those are just insulating tubes.
    BTW mine are all brown, and are brown on OEM Philips and Osram bulbs.
    ~Brian
    1998.5 A4 2.8QT
    Veteran Member Four Rings Undisputed's Avatar
    Jun 29 2008
    05' A4 USP, 00' Suburban, 07' Tahoe
    Are you seeing diminished light output? If you are, your bulb may be going out, although I think HID's just start to change color as opposed to getting dim.
    05' USP 6MT-REVO Stage II- Racetec- Stoptech 332- OCarbon Fiber Interior Trim- B7 RS4 Steering Wheel- VMR Boost Gauge- Siemens 380's- Bailey Motorsport DV- NGK Copper Plugs- LED tails- and a few other things
    -Damon-
    USP CLUB MEMBER #927
    Jun 26 2007
    '02 A4 1.8TQS
    Montreal
    Nope the bulbs and everything else are working just fine. I just saw some dirt and thought to clean it. If halogen are more sensitive to finger oil and are cleaned with 90% alcohool, I dont see how cleaning the HIDs can be more damaging.
    Jun 29 2008
    FWIW I don't recall ever seeing anything that said halogen was more sensitive to oil than HID's, but I don't think that cleaning it is going to make any type of difference so I just wouldn't bother.
    -Damon-
    Veteran Member Four Rings pOrKcHoP07's Avatar
    Oct 13 2007
    '85 E30 318i
    Yonkers, NY
    If it ain't broke, don't fix it.
    2003 Audi A4 1.8T Quattro
    AKA: masterforu2nv
    Current Mods:
    Debadge. 3000k DDM Tuning HID Fogs. 5000k DDM Tuning HID Kit. AWE Exhaust. Window/Fog Vag Mod. VMAXX Coilovers. Enkei Raijins. Adam Rotors. Hawk HPS Pads. SS Brake Lines. RAI Testpipe. Racetec FMIC. JHM SS. Motoza Stage 1 Chip.Evolution Racewerks TIP.
    Jun 26 2007
    '02 A4 1.8TQS
    Montreal
    Quote Originally Posted by pOrKcHoP07 View Post
    I guess that makes sense. I will put it back as is and if I have problems with it, I will clean it as a last shot b4 getting another bulb.
    Aug 26 2005
    Quote Originally Posted by jackyaudi View Post
    If it makes you feel better, it's OK to use denatured alcohol and a cotton ball to clean the quarts capsule and the insulator tube.
