Results 1 to 4 of 4
    Senior Member Three Rings tamaneri's Avatar
    Apr 02 2007
    New Jersey (Northern)
    new spark plugs / ignition coils
    Hey guys... installing new new spark plugs / ignition coils and noticed this bit of oil when I was taking out the plugs (it was also all over the plugs obviously, and on some of the ignition coils... I tried to take the best pics I could.
    Do I have a problem here? Or should I ignore it and install new items?
    Taylor A. Maneri
    2003 A4 1.8TQ B6 Black/Black
    Unitronic Stage 2 | TT 386cc injectors | RAI test pipe | Magnaflow 16601 | Milltek downpipe | Forge 007 DV | rs4 rear sway | vent pod boost gauge | JHM short throw | 034 engine mounts | ARP snub | ECS RA4 stage 1 clutch/flywheel | Bilstein / H&R
    tamaneri (AIM)
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    Re: new spark plugs / ignition coils
    Looks like the center valve cover gasket needs to be replaced. Here's a link to the DIY that audipotential provided.
    http://www.audizine.com/forum/showthread.php?t=210420
    good luck!
    Veteran Member Four Rings Arclight's Avatar
    Dec 20 2006
    8VS3
    +1 on the valve cover gasket. Martini's site, A4mods.com, has a DIY.
    For Sale: HRE 501s, 19 X 8.5 and 19 X 9.5
    Apr 02 2007
    cheap fix, woohoo!! thanks guys =)
    Taylor A. Maneri
    tamaneri (AIM)
