FSI stands for fuel stratified injection. It was tried and failed because of the complexity to control the direction of fuel near the spark plug at high rpms (>2.5k). Basically, you have a lot of unburned fuel which causes lots of emissions problems... Due to the extremely difficult control and the little benefits, it was aborted and most companies adopted homogenous injection. Or a combination of stratified at low RPMs and homogenous at the higher RPMs. Why does audi keep FSI as their trademark...who knows, probably some marketing guy really really likes it.
Read the wiki info site, it does a decent job explaining what DI is all about. In general, the fuel is sprayed directly into the combustion chamber (hence direct injection). Meanwhile, PFI (port fuel injection) is sprayed into the intake manifold and is mixed with the incomming air. With DI, the fuel is injected at extremely high pressures (40bar) which is more efficient than PFI because of various reasons: better control during intake stroke at the optimal piston position rather than in PFI it comes in with the air, and the fuel droplet size is smaller which means more burned fuel near the spark plug which is higher energy output.
The bad with DI is that it is more expensive than PFI; however, the benefits with fuel economy and emissions usually superceed the cost (at least in the US and Eu...in Latin America - not so much).
I'm sure someone else can expand on my explanation but that is all i can think of at the moment...
