Results 1 to 11 of 11
    Veteran Member Four Rings 01audia4's Avatar
    Jan 31 2008
    Philly home of the cheesesteak
    Gone bad, very. Help
    Ive been having a bunch of problems with my car, Major little things(things that i can figure out) TRE, Control Arms, Struts, BS problems. But this.....
    When i am in parking lot speeds, we will say 20MPH in 3rd gear that brings me to about 1K..My car stutters like crazy. It is only 3,4&5 Gear that does it though, and as soon as i go above say 1500 RPM's it wont stutter.
    When i am turning shift into 3rd pull into the street hit the gas car goes...Then stutters feels like it is almost going to stall. It feels like a very shaky start up with someone who doesn't know how to drive stick.
    Any Ideas?
    2001 A4 2.8-->1999 a4 1.8tq 220K-->2000 K04 S4--->2001 F21 S4 eating corn w/ stock rods
    Veteran Member Four Rings AudiXS4X01's Avatar
    Nov 11 2006
    01 Audi S4-Santorin Blue
    Tri-State
    Re: Gone bad, very. Help
    coilpack maybe?
    Veteran Member Four Rings Jibberific's Avatar
    May 21 2008
    az
    maybe every single drivetrain mount is broken
    {99.5 Avant}
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    check engine and trans mounts. your is car dbw. maybe the throttle body is dirty and its trying to compensate. take off the boot to it and check for brown residue around the rim of the plate. clean with throttle body cleaner spray while key on engine off, and accelerator pedal depressed. re-adapt by cylcing key and leave in on position for 2-5min before starting. or if you have vag-com, check mvb 3 field 3. at idle, throttle angle should be below 3%. if above, clean the throttle as stated. then re-adapt using basic settings block 60 with key on engine off. Are there any recent major mods prior to this occurring? does it do it when it's cold, warmed up, or all the time?
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Active Member Four Rings burner799's Avatar
    Oct 14 2006
    Hermosa Beach/PHX AZ
    ...20mph in 3rd gear sounds like your car is just almost stalling...why don't you downshift.
    Ti.Sline: yeah my dads got shit in order
    SkunkonCrunk: i had to pay $300 and fight the city after they sprayed a bike lane on my car
    SkunkonCrunk: i hear ya, i know u guys dont get along but let bigons be bigons, or however u spell it, im at a two year
    Jan 31 2008
    Quote Originally Posted by Jibberific View Post
    I thought about that but it only does it in the low RPM Area.
    Quote Originally Posted by B5A4Kevin View Post
    Thanks for the help ill try it. Does it while its cold and warmed up.
    Quote Originally Posted by burner799 View Post
    I'm at like 1100 1200 RPM the car isnt stalling. 2nd gear syncro is gone.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    What he said. You're driving a 6cyl, they don't have the low end grunt of a V8, that was cool when I had my Camaro, not now.
    The shutter/stutter you're feeling is a combo of all the drivetrain slop. OEM mounts are pretty buttery, dual mass flywheel, etc. You're applying torque to the drivetrain and it's mechanically fighting back. Our gear ratios are short for a reason.
    My car normally operates, aside from pulling away from a stop light, from 2000-3500rpm. That allows smooth engagement of each gear, decent fuel mileage and no bucking, stuttering, shuttering, or beating the hell out of my rod bearings.
    EDIT: I re-read above, my 6cyl would do the same thing, for the same reasons explained above. The more rotating mass and engine has the less likely it is to do what you describe. This is why my Camaro didn't do it, and my Audi does.
    Veteran Member Four Rings MultiAudis's Avatar
    Mar 12 2006
    01 Allroad 6mt, 01 A4
    NoVa
    thats what I was thinking
    Oct 14 2006
    didn't notice you have a 2.8..my bad
    Jan 31 2008
    If someone would listen...
    NEVER USED TO HAPPEN..
    Anyways i have a bigger problem, i think my TRE's are seized on to my tre :( Uhhohh check other thread.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Get it checked out as soon as possible. Or tear into it with a notepad and digital camera so you can make notes on everything wrong. Then get it all back together and rolling while you plan your attack and get your hands on some parts. Then the next weekend you can do some real work and fix it for good.
    Jim
    I Do Werk.
