I am trying to replace the passenger side front axle on my 1999 A4 quattro 2.8 V6 5 speed. I cannot get the old ale out. I have followed the DIY instructions posted by Wholsea and it looks like I need to disconnect the upper control arm to give me enough room to remove the axle. My Problem is that I cannot get the bolt that retains the upper ball joints out. I have removed the nut but the bolt will not budge. I have applied PB Blaster and Hammered onb the end (with the nut on to protect the threads) but it will not budge. Does it have to be removerd or just lossened? I did not try to drive teh ball joints out yet because I was not sure if the bolt has to be removed or not. Thanks If this is a duplicate post I appologise. I posted it earlier and I could not find it. If it did not post to the correct place please pm me. Thanks
