Results 1 to 9 of 9
    Veteran Member Three Rings drexplode's Avatar
    Jul 19 2007
    2016 M3 - maximum hooligan
    Michigan
    need some help - coolant leak
    Hey guys, I just got home about 20 mins ago and then poke my head into the garage and found a small coolant leak on the ground. Open up the reservoir and it gushes out.
    Checked the following:
    -coolant reservoir
    -coolant hoses to radiator
    -radiator
    I cant think of another place where it would be coming from. It appears the drips are coming from somewhere in the middle of the engine (not the back, not the front). My mechanic thought it might be the coolant temp sensor...?
    What are your thoughts???
    Car = 1999 A4 2.8 w/ 117k miles.
    pics:
    "A turbo boost gauge the size of a fat spaniels face! - Jeremy Clarkson
    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    Re: need some help - coolant leak
    not sure if the CTS would cause it to leak. It could be coming from you aux water pump
    00' Cactus, GIAC,H&R coilovers,original K03's for the time being..
    Jul 19 2007
    Michigan
    sorry guys, i just realized i posted in the S4 forum...doh!
    Feb 23 2008
    Atlanta, GA
    not a big deal; the water gushing is normal our systems work under pressure when hot
    Veteran Member Four Rings 1997gtx's Avatar
    Sep 14 2006
    14 GLI
    Moving to A4 section for 'ya ... If it were an S4, i'd be the after-run pump / aux. water pump.
    --Adam
    Have questions? E-mail me.
    Registered Member Two Rings
    Apr 19 2008
    215 PA
    in the back of the cylinder head there is a flange going into your block it id a common problem check it out!!
    Jul 19 2007
    Michigan
    root cause was determined to be a hose on the back of the aux water pump. Should be fixed by mon/tues.
    Sep 14 2006
    14 GLI
    Seems to be the same problem on the S4 and A4 :)
    Glad it's gonna be an easy fix
    --Adam
    Registered Member Two Rings lukepl's Avatar
    May 14 2008
    valley stream, ny
    im having the same problem except in mine i go from min to empty on the coolant reservoir in a month. I would like to find the source of the leak. Where is the water pump located? any diagram available? thx
