Results 1 to 17 of 17
Thread: Need help...
    Established Member Two Rings EnviedA6's Avatar
    May 06 2008
    Minneapolis, MN
    Need help...
    Ok so I go to drive my car about an hour ago after cleaning it, to go get gas before the hike up the price and noticed that I couldn't boost past 7psi. I was like, "that's strange I normally boost at 17psi". I come back home to see if there's a boost leak....found nothing. Checked my TBB boot that I had replaced 3 months ago and.....nothing. Both turbo's spool the way they normally do but I can't find a leak. Is this ad DV problem or is there something else that I should be looking at?
    Anything would help at this point...going to go drive the car again..grrr
    Envied A6
    2001 Silver Audi A6 2.7T Tiptronic, APR Stage 2 chip, Blitz custom intake, Dynomax Turbo custom exhaust, Custom down pipes, Turbosmart MBC, Carbon Fiber interior trim, arm rest, engine cover, air box cover, hood,trunk, mirrors, B pillars, eyebrows,Tinted tails & side markers, H&R lowering springs, H&R 5mm and 10mm wheel spacers, 19x9 Konig Next wheels, 245/35/19 Toyo Proxeys 4
    Apr 18 2007
    ny
    Re: Need help...
    DV's prob. need changing
    Forum Moderator Four Rings doobiesdaddy's Avatar
    Sep 05 2008
    2001 Stage 3 allroad 2.7t 6mt TDI gearbox , 2021 Mercedes E 350
    Montana / San Francisco
    Re: Need help...
    may need chip to be re flashed
    Dave - Moderator
    Issue? send me an email
    When I went to school, they asked me what I wanted to be when I grew up. I wrote down ‘happy’. They told me I didn’t understand the assignment, and I told them they didn’t understand life.
    -John Lennon
    May 06 2008
    Minneapolis, MN
    Re: Need help...
    Just got back and the same thing. The car seems to not be as strong as it used to.
    I can see the DV's needing to be replaced but for the ECU to be reflashed? Has this happened to other before, where they had to get their ECU reflashed?
    Everything sounds fine...I don't want to pay to have my ECU reflashed, rather spend the money towards new DV's or QTEC dump valves...still need more info on this problem
    Envied A6
    Apr 18 2007
    ny
    Re: Need help...
    Drive with your windows down and go full throttle, check to see if you hear any honking or hissing.
    May 06 2008
    Minneapolis, MN
    Re: Need help...
    Quote Originally Posted by A62TURBO View Post
    I did that as well and didn't hear anything but then again I can only hear my dang exhaust and the turbos spooling, no bucking, no hesitation ...nothing. I'm clueless...
    Envied A6
    Veteran Member Four Rings 2.slowT's Avatar
    Sep 24 2006
    2002 Audi A6 2.7T
    Minneapolis MN
    Re: Need help...
    Its easy to check your DV's.
    2002 A6 2.7T Sport
    2000 A4 Avant Daily
    C5UNION | pictures & timeline
    May 06 2008
    Minneapolis, MN
    Re: Need help...
    Quote Originally Posted by 2.slowT View Post
    Can you tell me how to do this so I can mark DV's off the list of possible things to replace? I'm stuck between boost leak, limp mode (hidden codes), and the DV's.
    Envied A6
    Sep 24 2006
    2002 Audi A6 2.7T
    Minneapolis MN
    Re: Need help...
    Remove the DV and push down on the valve while holding your finger over the intake hole (little hole). The valve should stick untill you release pressure.
    2002 A6 2.7T Sport
    2000 A4 Avant Daily
    Sep 05 2008
    Re: Need help...
    Quote Originally Posted by EnviedA6 View Post
    should be free to re flash from your local APR dealer. I had a similar problem but too much boost. I was boosting at 2 bar and I thought it was an intake leak or boost leak, but it turned out to be a gremlin in the APR program and a flash of the upgraded software took care of the problem.
    Dave - Moderator
    -John Lennon
    Sep 05 2008
    Re: Need help...
    what version of the software are you running?
    Dave - Moderator
    -John Lennon
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    Re: Need help...
    Do what 2.slowT said. Test the DV's that way. If one or both are messed up, it could be the problem. You should replace them anyway with just some 710n's. They are like $40 a pop.
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Nov 19 2005
    Pair of (. )( .)
    Re: Need help...
    how is the engine sounds? does it sound like a subary? doeas it shake? it can be anything...do you have a CEL? any codes? you are in the LIMP mode, something is wrong, can be mechanical as well as electrical problem. check if you have any codes. That would help us to point you into the right direction.
    -Andrey
    Stanced and Tuned Brilliant Black RWD C5 A6 2.7T 6MT
    May 06 2008
    Minneapolis, MN
    Re: Need help...
    Ok - checked for codes and scanned for anything that would cause this problem and had them cleared. Went for a drive and.....ahhhhh 17psi hmmmm it's sooooooo nice, smooth and strong like it was. NO MORE 5-7psi!!!!!
    I just want to thank everyone for there knowledgable thoughts and opinons. I was in limp mode and it had to do with the N75 valve so once the codes were cleared, everything was fine and back to normal.
    THANKS FOR EVERYTHING GUYS!!!!!!!!!!!
    Envied A6
    Veteran Member Four Rings deucescorner's Avatar
    Aug 26 2008
    None
    None
    Re: Need help...
    good to hear man
    sorry to jack your thread but what's LIMP mode?
    Nov 19 2005
    Pair of (. )( .)
    Re: Need help...
    LIMP mode is a engine power cut-off, your ECU(in car computer) is responsible for it, if something wrong, not enough air or gasoline it will shut off some power and wont give you to go more then 5 psi, enough to get you home and not harm your engine ;)
    thats how i understand it.
    -Andrey
    May 06 2008
    Minneapolis, MN
    Re: Need help...
    Quote Originally Posted by kievskiy View Post
    Yeah, I figured that too. The RS4/ S4 guys told me something different but I feel what you're saying. One of the S4 guys said that he came across the same problem and I followed what he did to fix it and it worked. He stated that he was in limp mode and everyone on that thread agreed as well. Everyone has there own opinon on what limp mode is but with me it was partially the ECU and the N75 valve.
    Envied A6
