Originally Posted by
turbo4s
Yeah I do 1-4 every day. Getting onto the highway.
LOL AWESOME I know on ramps are the full throttle play grounds for me.
Ok do this if you can.
Run the car in tip mode from a stop Full throttle (but don't shift let the MAX rpm shift the car for you) by default the car will up shift on its own. If you have a Vag com this would be easier for you to see. But let me know what RPM you up shift at. should be around 64-6500 RPM
Then put it in S mode and do that same thing 3 times But just keep it in S mode and don't touch it. Just S mode and from a stop take it all the way threw the shift into 4th. Let me know if the shift RPM goes up to say 68-6900 RPM.
The reason I ask is I don't remember my car doing this before I got a chip in my car. Now in S mode it almost shifts a 7K I love it.
So I reset my car. And did what I just asked you to do. I put it in tip and go from a stop all out threw the 4th gear shift. letting the MAX RPM up shift the car I don't shift it at all. The car shifts at 64-6500 RPM
The I put the car in S mode. Do the same thing. The first time the car will up shift at 6500. Then the second time 67-6800 RPM The vag com reads lime 6840 If I remember correctly.
NOW for the interesting thing. After you have done this in S mode Go back to tip mode and now your car should be up shifting at the MAX of 6800 RPM.
Or that is what I have seen. I would love to know if we stumbled on something here.
Thanks let us know. Enjoy your self.....but not too much
