Results 1 to 6 of 6
    Senior Member Two Rings Allaidback's Avatar
    May 23 2008
    Columbia, SC
    GIAC Boost Controller Flash File
    I bought the car with the software already installed so I'm not sure if it has the file or not, but I downloaded it and ran the file and it displayed my current setting and allowed me to up the boost. I just wanted to know if anyone has tried to install the software that didn't have the flash and it ran correctly? I have a mbc so I haven't actually tested it yet. Also the adjustments are from 210-255. I was thinking this was mbar and not psi? So is 250 actually 25psi or is it 2500 mbar = 22psi?
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    Re: GIAC Boost Controller Flash File
    2500 mbar is 2.5 bar.. so i dont think its that.. considering 2.5 bar is like 33psi
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Active Member Four Rings RogueStatus's Avatar
    Nov 13 2007
    B5 S4 Avant
    Boston
    yea 1 bar is like 14psi i believe. are you stage 3? i thought this file was only available on stage 3 software...
    Deactivated Four Rings
    Jul 16 2007
    2000 A4 Avant 1.9L BT
    Irvine, CA
    Quote Originally Posted by JDM EJ1 95 View Post
    you are forgetting to subtract for ambient pressure which is 1000 mbar at sealevel. 2550 mbar at sea level would be 1.55 bar or about 22.5 psi.
    That said, the numbers are just integers. 210 is the base setting, you can play with the boost controller and move the boost up as you like. Just make sure you have enough octane to do so as the boost will be corrected out if knock gets too high.
    May 23 2008
    Columbia, SC
    so i'm right in saying that the boost setting is in mbar and not in psi?
    Feb 28 2007
    chicagoland
    no what austin is saying is that(i think) the numbers are just random integers.. and there is no set value for them. just play with it until you get the right setting
    Nogaro 01 s4
    620whp 93octane
