Results 1 to 4 of 4
    Established Member Two Rings Dr.Coxx's Avatar
    Aug 23 2008
    B5 A4 1.8T
    Jacksonville FL
    Question Need some help guys
    Hey I’m having some trouble with my car. Its a B5 A4 1.8T. 1st the battery was low on the car. I was going to leave to replace it. I haven’t been driving it much because I’m currently unemployed. So its been sitting for a few days at a time. I’ve been having to jump it to start it. Today I was on my way to get the batt. and had to jump it. It started but it gave me a CEL. Every time I give it gas it drops below 1k rpms and almost dies. Can anyone help me? Any guesses?
    Thanks, Jason
    Veteran Member Four Rings boostedup's Avatar
    Sep 01 2005
    01 a4 1.8T,00 suzuki GSXR 600, 1974 Mako 171
    internationally known, Florida
    Re: Need some help guys
    sounds like a MAF problem. Vag it, or scan with obdII scanner for codes. you will get ALOT more help.
    you help us help you...........
    Santorin Blue 2001.5 Audi A4 1.8turbo Quattro with Sports, Celebration, Cold Weather Packages.
    Engine:APR 93 octane. Catch Can. Air Intake/Heatsheild. 710N .
    Interior:VDO Vent Boost gauge. Short Shift. Garmin GPS. 2-10" subs. Suede interior
    Exterior:19" ASA St4's/NITTO rubber. Neuspeed Race/Bilstein Sport shocks. 15% tint. Debadge. Clear Corners. 4300K HID. MS Design Front lip
    Aug 23 2008
    B5 A4 1.8T
    Jacksonville FL
    Quote Originally Posted by boostedup View Post
    Yea I know but I tried to drive it to get the codes but couldnt get it to go.
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    first thing is pull up any stored codes, dont have to drive it or start it even to pull up any codes. Is the CEL still on? Does your battery charge when you turn the car on?(should get to be around 14V)
