Results 1 to 13 of 13
    Veteran Member Three Rings windyctyaudi's Avatar
    Jul 30 2007
    '12 S4 prestige DSG
    Chicago
    Question about dead battery and alarm?
    I woke up today only to find that my battery on my car was completely dead, key fob wouldn't work, no lights the dash, nothing. So as soon as I jumped it my alarm starting going off. Is this normal? my battery has gone dead before but never has the alarm started going off as soon as I jumped it. Could my alarm have gone off last night and killed my battery?
    Aug 26 2005
    Re: Question about dead battery and alarm?
    Quote Originally Posted by windyctyaudi View Post
    The alarm won't sound for more than a few miniuites, so that isn't the reason the batt was dead. The reason the alarm sounded off when you jumped the car, was because the system was armed when the batt died, and when power was restored, that was the state of the controller, armed. There is some other reason the battery was dead. If your battery has cell caps under the stickers on top, you should fill each cell with distilled water, but leave about 1/4" air space between the fluid surface and the lower rim of the cell port. Then, use a regluated battery charger and slow charge the battery for at least 24 hours. If the battery goes dead again right away, either there is a load on the battery with the car OFF, or the battery is shot.
    You must also make sure there is NO WATER accumulation inside the ECU box. It is a known problem, if water leaks into the ECU box, it shorts out the electricals inside, and can drain the battery quickly.
    Jul 30 2007
    '12 S4 prestige DSG
    Chicago
    Do OEM batteries have caps for water? i looked at mine and it didnt look like the topa came off, i want sure i didnt want to mess with it.
    Aug 26 2005
    My '03 has caps. The warning label stickers cover the caps. My batt has a Magic Eye that is one of the six cell caps. If your batt has the ME, then it has caps also. Peeling off a sticker partially will reveal the cell caps they have wide slots in the surface crossing, +, to use a coin to remove the cap. Most premature batt failures are due to needing a top up on the cells, but never get it, and are replaced instead.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    How old is the battery? Did you have a recent cold front? That will kill a seeming good but on it's way out battery.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Senior Member Three Rings tamaneri's Avatar
    Apr 02 2007
    New Jersey (Northern)
    my batter is effed up. I have an '03... any pics as to what I should do to try and revive it before I spend money replacing an item that is perfectly fine?
    Taylor A. Maneri
    2003 A4 1.8TQ B6 Black/Black
    Unitronic Stage 2 | TT 386cc injectors | RAI test pipe | Magnaflow 16601 | Milltek downpipe | Forge 007 DV | rs4 rear sway | vent pod boost gauge | JHM short throw | 034 engine mounts | ARP snub | ECS RA4 stage 1 clutch/flywheel | Bilstein / H&R
    tamaneri (AIM)
    Jul 30 2007
    '12 S4 prestige DSG
    Chicago
    Quote Originally Posted by dirtybrd View Post
    my car is a 02 but i got it used in 06 as far as i know its the origonal, yes it has been in the 30's here at night for the past week or so, i was thinking her time might eb up and i should just get a new one.
    Veteran Member Three Rings PCYC's Avatar
    Sep 07 2007
    04 A4 3.0 6spd, 06 A6
    Atlanta GA
    buy a optima yellow top D35
    Mar 21 2006
    Lakeland, FL.
    Sounds like it.
    I'm back bitches!
    Aug 26 2005
    Quote Originally Posted by tamaneri View Post
    "If your battery has cell caps under the stickers on top, you should fill each cell with distilled water, but leave about 1/4" air space between the fluid surface and the lower rim of the cell port. Then, use a regulated battery charger and slow charge the battery for at least 24 hours."
    Performing the steps above, may save a battery that is low on electrolye, however, if it's been low enough that the top of the lead plates in the cell/s have been dry too long, the damage may be too extensive to recover. Doesn't hurt to try first regardless.
    Jul 30 2007
    '12 S4 prestige DSG
    Chicago
    Ok so an update to my battery problem. I took you advice diagnosticator and added distilled water to the battery, it was pretty much bone dry i had to add almost 2/3 of a gallon to the battery and afterwards. My CEL came on and i checked it and the code was for low voltage. Do i need to go get a batter charger and charge it up or could i just drive the car around for awhile and let it idle to charge it up?
    Aug 26 2005
    Highway driving will recharge the battery, but in this situation, a good charger set to charge at a low amp charge rate, ( like 2 amps max,) for at least 24-36 hours, (doesn't have to be at the same time uninterrupted, put it on the charger overnight for 3 or 4 days will work the same,) will allow the battery to recover fully. It's the low amp rate over many hours that recharges the battery completely, the high amps rate while driving doesn't perform the recharge as completely as possible, so the maximum capacity may not be restored fully if only charged while driving. A good charger new can be bought for less than $40.
    You can try driving to charge up only, then test the battery voltage with a digital multimeter, it must be at least 13.2 volts (no load) to be charged completely. A slow rate charge on a charger is my recommendation for the best possible chance for reviving the battery to extend the useful life span a practical amount time.
    Jul 30 2007
    '12 S4 prestige DSG
    Chicago
    Thanks for all the help
