Results 1 to 13 of 13
    Veteran Member Four Rings J Ozzie's Avatar
    Jun 06 2008
    Port Moody, Canada
    How big of tire can i go on Stockies...
    Im lookin at gettin some winter tires and im either gonna stick with stock size or go 225 55 r15... will that fit on stockies?
    Says the tire size calculator.
    2014 Audi Q5 TDI - Brilliant Black | LED Fogs | VCDS Mods | LED Interior swap |
    R.I.P... (wrecked)2005 Audi A4 1.8TQM 6Speed
    R.I.P..2001 Audi a4 1.8TQM (casa white no sunroof)
    Vancouver Audi Club.ca
    where's our resident intoxicated lobster Canadian - Thomas
    Dec 04 2007
    New York, NY
    Re: How big of tire can i go on Stockies...
    do they even make 225-55-15?
    I was thinking of going 205-65-16 vs 205-60-16.
    arent your stock rims 16" ?
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    I had 225 55 16 on my 16in mini rs4 stockers.
    TEAM|AXION
    Senior Member Three Rings Insomniac's Avatar
    Jun 03 2008
    Hershey
    I believe you want a skinnier tire in winter conditions. Cuts through the snow better than a wider one.
    free earl
    2009 A3 2.0T Quattro S-Line
    Vancouver, BC Canada
    True~
    Quote Originally Posted by Insomniac View Post
    IG:@steadysupreme
    Pics&Detail
    Veteran Member Four Rings D's Avant's Avatar
    Oct 03 2007
    02 BMW 330i
    Illinois
    205's will be a better winter tire than a 225 tire. I've run both as a winter tire and the 205's slid/broke away much smoother while playing in the snow. 225's seem to float on top of the snow more and I had more understeer. 205's will be more predictable/stable when you are out having fun in the snow.
    Current '08 A6 Avant S-Line
    Former '99 A4 Avant 1.8t
    Apr 22 2007
    Riverbank, Ca
    Im running 225 50 16's on my sport 16's and 205 60 15's on my 15's, they fit the wheel much better than a 225. I would just go 205 60 15's.
    Jun 06 2008
    Port Moody, Canada
    Yeah i figured id need a thinner tire...as apose to a wide one. My rims are only 15's im goin to use the stockies for winter and buy something in the spring :)
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    You guys aren't even talking about the right sizes here. 225/50-16 or 205/55-16 are the correct sizes for a 16" wheel. The 205 will be much better in slush and wet conditions. The 225 will be better at slow speeds, on dry pavement, and in deep snow.
    Go with the narrow tire if you can. I ran a 245/40-17 snow tire last year and they were sketchy when crossing the slush median that forms between lanes on the freeway. Everywhere else they were just great though.
    Jim
    I Do Werk.
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    195/65/15 ideal snows
    Mar 09 2004
    nw michigan.
    195/55-17 on 17x7.
    Jim
    I Do Werk.
    Jun 06 2008
    Port Moody, Canada
    thanks for the replys, as i said i have 15's. I will go with 205's then and a 225 in the spring.
    Mar 09 2004
    nw michigan.
    No point in buying tires for 15" stockers when 16" stockers aren't much more.
    Jim
    I Do Werk.
