Results 1 to 4 of 4
    Veteran Member Three Rings GarbatyA4's Avatar
    Aug 10 2007
    Ontario Canada
    Outside Temperature Sensor - Question
    Ok, I have a FMIC on my car and my Outside Temp. Sensor is right below, couple inches away. I'm getting odd readings from the OTS? Is the sensor that sensitive? should I reposition the sensor somewhere else?
    Example... It's +7deg celsius right now. My car is reading +10.5deg, It's been sitting there all morning.
    2012 Audi Q5 - Daily (slow AF)
    2013 Mini Cooper S - sold
    2005 BMW 325Ci - sold
    2007 BMW 335i - sold
    2004 VW Golf TDI - sold
    2004 Audi S4 V8 Cabriolet - sold
    2003 Audi A4 1.8T - GT2871R - sold
    2000 GMC Sonoma - sold
    1992 Dodge Stealth RT - sold
    1991 Chevrolet Beretta GTZ - sold
    Veteran Member Four Rings ApexIt's Avatar
    May 28 2008
    2005 A4
    Re: Outside Temperature Sensor - Question
    so you havent turned the engine on at all and its giving you a bad reading? Maybe its not calibrated correctly or maybe the car is giving the correct temp and the one your using as a reference guide is off. I keep a thermometer in the east window of my house so every morning the reading is off on the thermometer in the window b/c the sun is shining on it. Check the temp from a couple of places (i.e the internet, your own thermometer, etc) and then compare. Little stuff like this bother me too so I hope this helps out a bit.
    Sep 23 2006
    Houston TX
    They're not that accurate anyway
    Aug 10 2007
    Ontario Canada
    I'm just going to relocate it away from any sources that would offset readings.
    for example, as im driving it reads +16deg, and its snowing? WTF
