Results 1 to 6 of 6
    Veteran Member Four Rings gotboost's Avatar
    Nov 04 2007
    Minnesota
    Tein Basic Coilovers
    Just wondering who's got them, how the ride and quality is and are they adjustable on the car? Thanks
    Current:
    2002 A4 Avant - Eibach Pro Dampers | Rev Motoring Springs | 034 Motor Mounts | 710N DV | Apikol Snub Mount | 18" S4 Peeler's
    2001 Imola S4 Satge 2+
    2003 A4 GT2871r 303 AWHP 291 AWTQ
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: Tein Basic Coilovers
    all of them are fine to adjust while on the car... to be honest you probably wont adjust it on the car anyway
    - Clint
    Feb 04 2008
    04 A4
    Dover, DE
    do you mean are the adjustable w/o lifting the car up? No. You can't adjust coilovers w/o jacking the car up.
    Registered Member Two Rings
    Oct 24 2008
    Orange County
    Quote Originally Posted by gotboost View Post
    I just purchased and installed a set of Tein Basics recently. The install is a PITA in the rears, front's where ok. As for adjustability, fronts are height adjustable and can be adjusted on the car, but for the rears, forget about it. You need to take the entire rear assembly out to adjust it. Once they are in, they are in unless you want to spend 3 hours disassembling the rear suspension just to do a few mm turns on the adjustment plate.
    If you do still decide to go the the Tein basics, set the rears all the way to the lowest setting. They have not settle yet because it's been only 5 hours since I just installed mine, but I have a 1 finger gap in the rear with 19's wrapped with 265/30/19 tires. I'm sure once they settle, I'll get about 1/2 finger gap which is what i'm after.
    As for ride, I think they a softer than my OEM USP sports suspension, but it's only been about 5 hours so I'll let you know exactly in a week or two.
    good luck
    Oct 29 2005
    10speed
    San Francisco, CA
    they handle damn good though
    - Clint
    Veteran Member Three Rings CrystalBlu1.8T's Avatar
    Sep 14 2006
    2017 RS3, 11 Q5 S-Line,
    I like them ride quality is fine and adjusting them i only do it twice a year for winter and summer setup.
