    Feb 21 2008
    Cleveland
    VAST CEL Eliminators not working any advice?
    I have the Vast CEL eliminators, to prevent a CEL because I am running cat-less but the codes do come on once every couple of months, O2 sensors are all new, so that is not the issue. If I add another spacer on each side will that solve my issue, if not do you guys have any advice.
    -Roman
    Senior Member Two Rings Allaidback's Avatar
    May 23 2008
    Columbia, SC
    Re: VAST CEL Eliminators not working any advice?
    Sh*t ton of threads about this but try adding 2 spark plug defoulers (18mm) on top of your vast eliminators, seemed to work for me.
    Feb 21 2008
    Cleveland
    anybody happen to know who makes the right angle adapters for these I remember seeing it on somebody's website.
    -Roman
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    the cel elimiters are overprices carp. all u need is two spark plug defoulers stacked on eachother with the inside drilled out a bit more than how it comes
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Veteran Member Three Rings b5s4tt's Avatar
    Mar 14 2007
    s4
    queens
    ive seen the right angle ones from weapon r and a seen http://yhst-1918367471896.stores.yahoo.net/oxsesp.html. i have 2 defoulers on each side with downpipes and straight pipe, and i have never thrown a code.
