Results 1 to 7 of 7
    Apr 19 2008
    Utah
    Lemmiwinks with Vista??
    I need some techie help. I've read through the posts that show how to make a VAG Com cable work with XP, but I can't get the same procedure to work on a laptop with Vista. Any ideas??
    Active Member Two Rings Cart's Avatar
    Apr 08 2007
    2001 Audi S4
    Chicagoland
    Re: Lemmiwinks with Vista??
    I am not sure what your exact problem is. You can make sure you have the correct com port set. Start > Control Panel > Hardware and Sound> Device Manager
    I dont have it open in front of me but i believe its under "Universal Serial Bus controllers" you can hit properties and change the com port. Make sure hte com port matches on Lemmi.
    Im trying to go off of memory here but its close to that.
    Veteran Member Four Rings veggiemonster's Avatar
    Oct 20 2008
    fuck off
    yeah i have the generic one for the chip and cant get a com port. just doesnt work
    Apr 08 2007
    2001 Audi S4
    Chicagoland
    I have the Generic cable as well. Is your cable USB? I Know the cable has a separate USB Driver
    Account Terminated Four Rings
    Sep 27 2007
    hate on me <3
    under the knife in, CT
    its easy to get it to work with vista, thats how mine is. my ebay usb cable does anything, its a newer one.
    the most youd have to do is right click and 'run as administrator', but usually i only have to do that with vag-com, not lemmiwinks. other then that its pretty straight forward.
    Veteran Member Three Rings Ko4S4WI's Avatar
    Aug 02 2008
    2001 S4
    Milwaukee
    My ross-tech cable works well in VISTA
    I can Use: Vag-Com, Lemmi, and ECU-x with out any problems.
    Mar 26 2007
    2001 S4, 1999.5 A4
    Chambersburg
    I had problems with my Ross-tech USB cable working with Lemmiwinks. Simple solution, get Unitronics Unisettings, version 1.4. It is free and does the same things that Lemmi does...
