However, while doing so, I mulled over the fact that there are a TON of vacuum lines that are not really necessary and deal mostly with emissions which are not a factor where I live. I quickly decided to simplify the underhood area, both to clean it up a bit, maybe have a marginal improvement in airflow and to lower the overall possible failure points with increased boost pressure. I already had to replace a portion of the vacuum system two months ago that set me back $57... in retrospect, I should have just done this back then.
Here is how my engine bay looks, stock and unmolested.
Here are some images at various stages throughout my working.
Here are the remains of this little adventure...
I got bored this afternoon at work and made this little guy out of 1/8" aluminum to block the port left on the back of the head by the SAI, the original gasket was still good and was reused. Much better than the $35 it'd cost for block-off plate from a IE.
I'm going to modify the stock airbox a bit and use a K&N drop-in filter. I also ordered a test pipe to replace the cat which should give a moderate increase in power and lower spool time as well as lower my underhood temps. My timing belt is meant to come at the same time, so it'll be a busy next two weeks for the A4.
