Ok well im kind of new at logging with vag. I was able to do it but its kind of hard to read. I checked the vac line going to the fpr and replaced anyways. Still no difference. It looks like at idle my maf is at 1.87. Then when i got to 5200 is was at 157. I will try to post the log but i have no clue how it will turn out. Thanks
Friday,31,October,2008,22:20:21
8D0 907 557 P,,1.8L R4/5VT MOTR HS D07,
,Group A:,'003,,,,Group B:,'032,,,,Group C:,'001
,,Engine,Air,Throttle,Ignition,,O2 Sens Learning,O2 Sens Learning,_,_,,Engine,Coolant,O2 Sensor,Adjustment
,TIME,Speed,Mass Flow,Angle,Timing,TIME,Val@Idle,Val@Part Ld,,,TIME,Speed,Temperature,Control,Conditions
Marker,STAMP, /min, g/s,°, °BTDC,STAMP, %, %,,,STAMP, /min,°C, %,
,0.01,840,1.87,2.6,12.8,0.26,4.7,-10.9, , ,0.52,840,90.0,-1.6, 111111
,0.78,840,1.87,2.6,12.0,1.04,4.7,-10.9, , ,1.31,840,90.0,0.8, 111111
,1.57,840,1.87,2.6,10.5,1.83,4.7,-10.9, , ,2.09,840,90.0,2.3, 111111
,2.39,840,1.87,2.6,10.5,2.65,4.7,-10.9, , ,2.91,880,90.0,2.3, 111111
,3.17,840,1.87,2.6,10.5,3.43,4.7,-10.9, , ,3.69,840,91.5,-0.8, 111111
,3.95,840,1.87,2.6,11.3,4.21,4.7,-10.9, , ,4.47,840,91.5,-2.3, 111111
,4.73,840,1.87,2.6,12.0,4.99,4.7,-10.9, , ,5.25,840,91.5,-3.9, 111111
,5.51,840,1.87,2.6,12.8,5.77,4.7,-10.9, , ,6.06,840,91.5,-0.8, 111111
,6.36,840,1.87,2.6,12.0,6.65,4.7,-10.9, , ,6.95,840,91.5,0.8, 111111
,7.24,840,1.87,2.6,11.3,7.53,4.7,-10.9, , ,7.82,840,91.5,2.3, 111111
,8.09,840,1.87,2.6,10.5,8.36,4.7,-10.9, , ,8.62,840,91.5,2.3, 111111
,8.88,840,1.87,2.6,10.5,9.14,4.7,-10.9, , ,9.40,840,91.5,-1.6, 111111
,9.70,840,1.87,2.6,12.0,9.96,4.7,-10.9, , ,10.22,840,91.5,-0.8, 111111
,10.48,840,1.87,2.6,9.8,10.74,4.7,-10.9, , ,11.00,880,91.5,1.6, 111111
,11.26,840,1.87,2.6,10.5,11.53,4.7,-10.9, , ,11.79,920,91.5,3.1, 101111
,12.05,1000,2.92,3.0,12.0,12.31,4.7,-10.9, , ,12.57,1040,91.5,5.5, 101011
,12.83,1000,3.89,5.2,15.8,13.09,4.7,-10.9, , ,13.35,920,91.5,5.5, 111111
,13.61,880,2.01,2.2,12.0,13.87,4.7,-10.9, , ,14.13,880,91.5,1.6, 111111
,14.39,840,1.73,2.2,12.0,14.65,4.7,-10.9, , ,14.91,800,91.5,0.0, 111111
,15.17,840,1.87,2.6,13.5,15.43,4.7,-10.9, , ,15.71,840,91.5,-2.3, 111111
,15.98,840,1.87,2.6,14.3,16.25,4.7,-10.9, , ,16.51,840,91.5,-3.9, 111111
,16.80,840,1.87,2.6,12.8,17.08,4.7,-10.9, , ,17.36,800,91.5,-6.3, 111111
,17.62,840,1.94,2.6,14.3,17.90,4.7,-10.9, , ,18.16,840,91.5,-3.9, 111111
,18.42,840,1.94,2.6,10.5,18.69,4.7,-10.9, , ,18.95,840,91.5,-1.6, 111111
,19.22,840,1.94,2.6,11.3,19.49,4.7,-10.9, , ,19.75,840,91.5,0.0, 111111
,20.01,840,1.94,2.6,13.5,20.27,4.7,-10.9, , ,20.53,840,91.5,2.3, 111111
,20.79,880,2.43,11.3,11.3,21.05,4.7,-10.9, , ,21.31,1240,91.5,2.3, 111111
,21.57,1200,2.29,5.2,16.5,21.83,4.7,-10.9, , ,22.09,1280,91.5,2.3, 101111
,22.35,1280,4.31,3.0,18.8,22.61,4.7,-10.9, , ,22.88,1240,91.5,2.3, 101011
,23.14,1280,4.72,15.2,20.3,23.40,4.7,-10.9, , ,23.66,1200,91.5,-2.3, 111111
,23.92,1000,2.29,3.5,12.0,24.18,4.7,-10.9, , ,24.44,960,91.5,-4.7, 111111
,24.71,840,1.81,3.0,14.3,24.97,4.7,-10.9, , ,25.23,1000,91.5,-7.0, 111111
,25.50,1160,6.11,3.9,12.8,25.77,4.7,-10.9, , ,26.04,1200,91.5,-10.9, 101011
,26.30,1200,7.01,17.8,30.0,26.57,4.7,-10.9, , ,26.84,1040,91.5,-14.8,
,27.12,1080,5.76,9.1,27.8,27.42,4.7,-10.9, , ,27.68,1360,91.5,-8.6, 101011
,27.98,1440,4.72,6.9,35.3,28.27,4.7,-10.9, , ,28.53,1520,91.5,-4.7, 111111
,28.79,1400,1.87,2.6,21.8,29.05,4.7,-10.9, , ,29.31,1200,91.5,-3.1, 111111
,29.57,1080,1.94,2.6,13.5,29.83,4.7,-10.9, , ,30.09,880,91.5,-3.1, 111111
,30.35,840,1.73,2.6,12.0,30.61,4.7,-10.9, , ,30.87,800,91.5,-7.0, 111111
,31.15,800,1.87,2.6,15.0,31.42,4.7,-10.9, , ,31.72,840,91.5,-3.1, 111111
,32.01,840,1.94,2.6,12.8,32.28,4.7,-10.9, , ,32.57,800,91.5,-1.6, 111111
,32.84,840,2.01,3.0,13.5,33.11,4.7,-10.9, , ,33.40,880,91.5,-0.8, 111111
,33.67,880,2.01,2.6,7.5,33.93,4.7,-10.9, , ,34.19,880,91.5,-3.1, 111111
,34.45,880,1.94,2.6,9.8,34.71,4.7,-10.9, , ,34.96,840,91.5,-2.3, 111111
,35.23,880,2.01,2.6,9.0,35.48,3.9,-10.9, , ,35.75,880,91.5,0.0, 111111
,36.02,880,4.72,22.6,13.5,36.29,3.9,-10.9, , ,36.56,1480,90.0,1.6, 101011
,36.85,1320,6.18,22.1,21.8,37.14,3.9,-10.9, , ,37.42,920,90.0,-0.8, 101011
,37.71,960,7.92,19.5,24.0,37.97,3.9,-10.9, , ,38.23,1360,90.0,-5.5, 101011
,38.49,1560,13.47,23.9,35.3,38.74,3.9,-10.9, , ,39.01,1960,90.0,-1.6,
,39.28,2160,19.65,28.2,38.3,39.57,3.9,-10.9, , ,39.83,2640,90.0,0.0, 101001
,40.10,2880,28.12,31.7,33.0,40.35,3.9,-10.9, , ,40.62,3360,90.0,2.3, 101001
,40.88,3600,28.26,24.7,39.8,41.15,3.9,-10.9, , ,41.41,3400,90.0,0.0, 110001
,41.68,3040,3.12,5.6,33.8,41.94,3.9,-10.9, , ,42.21,2280,90.0,0.0, 100001
,42.49,2000,10.34,20.8,36.0,42.75,3.9,-10.9, , ,43.00,2120,90.0,-5.5,
,43.27,2200,21.67,32.1,36.8,43.52,3.9,-10.9, , ,43.78,2360,90.0,2.3, 101001
,44.04,2400,24.09,31.7,33.8,44.30,3.9,-10.9, , ,44.57,2600,90.0,10.2,
,44.82,2680,27.64,31.2,31.5,45.08,3.9,-10.9, , ,45.35,2840,90.0,12.5,
,45.61,2920,30.56,30.4,32.3,45.87,3.9,-10.9, , ,46.13,3080,90.0,8.6, 101001
,46.38,3160,31.81,29.9,33.0,46.64,3.9,-10.9, , ,46.90,3280,90.0,7.0, 101001
,47.16,3360,32.36,29.5,35.3,47.43,3.9,-10.9, , ,47.68,3440,90.0,8.6, 101001
,47.98,3520,32.36,28.6,36.8,48.25,3.9,-10.9, , ,48.53,3640,90.0,7.0, 101001
,48.80,3680,31.59,28.2,38.3,49.08,3.9,-10.9, , ,49.37,3800,90.0,7.0, 101001
,49.68,3880,51.53,77.3,30.0,49.97,3.9,-10.9, , ,50.25,4200,90.0,0.0, 100001
,50.52,4440,106.18,85.9,24.0,50.78,3.9,-10.9, , ,51.05,5000,90.0,0.0,
,51.34,5240,157.64,85.5,18.0,51.61,3.9,-10.9, , ,51.87,4880,90.0,0.0,
,52.17,4400,5.56,10.0,37.5,52.44,3.9,-10.9, , ,52.72,3600,90.0,0.0, 100001
,52.99,3400,9.86,14.8,30.8,53.28,3.9,-10.9, , ,53.54,3360,90.0,3.1, 101001
,53.82,3320,10.21,14.8,30.8,54.10,3.9,-10.9, , ,54.38,3280,90.0,7.0, 101001
,54.65,3240,3.54,4.8,35.3,54.91,3.9,-10.9, , ,55.18,3160,90.0,0.0, 110101
,55.44,3120,3.26,4.3,34.5,55.72,3.9,-10.9, , ,55.97,3040,90.0,0.0, 110101
,56.25,3000,2.98,4.3,33.0,56.52,3.9,-10.9, , ,56.78,2880,88.5,0.0, 110101
,57.04,2880,2.84,3.9,32.3,57.30,3.9,-10.9, , ,57.56,2800,88.5,0.0, 110101
,57.82,2760,2.84,3.5,31.5,58.08,3.9,-10.9, , ,58.34,2680,88.5,0.0, 100001
,58.61,2680,6.81,12.6,33.8,58.86,3.9,-10.9, , ,59.12,2600,88.5,1.6, 101001
,59.39,2640,11.67,17.8,36.8,59.65,3.9,-10.9, , ,59.91,2600,88.5,1.6, 101001
,60.17,2600,17.98,23.4,38.3,60.43,3.9,-10.9, , ,60.69,2640,88.5,3.1, 101001
,60.96,2640,14.58,19.1,38.3,61.23,3.9,-10.9, , ,61.49,2680,88.5,4.7, 101001
,61.76,2680,17.57,22.1,38.3,62.02,3.9,-10.9, , ,62.29,2720,87.0,0.8, 101001
,62.55,2720,16.04,20.4,38.3,62.81,3.9,-10.9, , ,63.07,2760,87.0,3.1, 101001
,63.33,2760,12.50,16.9,36.0,63.60,3.9,-10.9, , ,63.86,2760,88.5,3.1, 101001
,64.12,2760,9.17,13.5,33.0,64.38,3.9,-10.9, , ,64.64,2760,88.5,3.1, 101001
,64.90,2720,9.03,13.5,33.0,65.20,3.9,-10.9, , ,65.46,2720,88.5,4.7, 101001
,65.72,2720,7.01,10.9,33.0,65.98,3.9,-10.9, , ,66.24,2680,88.5,5.5, 101001
,66.50,2680,6.87,10.9,33.0,66.76,3.9,-10.9, , ,67.02,2680,88.5,12.5, 101001
,67.28,2680,7.01,11.3,33.8,67.54,3.9,-10.9, , ,67.80,2680,88.5,14.1, 101001
,68.06,2680,7.50,11.7,33.8,68.32,3.9,-10.9, , ,68.58,2680,88.5,10.9, 101001
,68.85,2640,7.50,11.7,34.5,69.11,3.9,-10.9, , ,69.38,2640,90.0,3.9, 101001
,69.64,2640,7.78,12.6,34.5,69.91,3.9,-10.9, , ,70.17,2640,90.0,10.2, 101001
,70.43,2640,8.75,13.5,34.5,70.69,3.9,-10.9, , ,70.95,2640,90.0,10.2, 101001
,71.21,2640,8.61,13.5,34.5,71.47,3.9,-10.9, , ,71.73,2640,90.0,3.1, 101001
,72.02,2640,7.50,11.7,34.5,72.29,3.9,-10.9, , ,72.55,2640,90.0,10.2, 101001
,72.81,2600,8.61,13.5,35.3,73.07,3.9,-10.9, , ,73.33,2600,90.0,10.9, 101001
,73.60,2640,8.19,12.6,35.3,73.86,3.9,-10.9, , ,74.12,2600,90.0,7.0, 101001
,74.39,2600,7.01,11.3,35.3,74.69,3.9,-10.9, , ,74.94,2600,90.0,11.7, 101001
,75.20,2600,6.73,10.4,35.3,75.46,3.9,-10.9, , ,75.72,2600,90.0,14.8, 101001
,75.99,2560,5.56,8.2,36.0,76.25,3.9,-10.9, , ,76.51,2560,90.0,14.8, 101001
,76.77,2520,4.86,7.4,36.8,77.04,3.9,-10.9, , ,77.30,2520,90.0,17.2, 111101
,77.56,2480,2.78,3.5,29.3,77.82,3.9,-10.9, , ,78.08,2440,90.0,0.0, 110101
,78.34,2440,2.50,3.0,29.3,78.60,3.9,-10.9, , ,78.86,2360,90.0,0.0, 110101
,79.12,2320,2.57,3.5,28.5,79.38,3.9,-10.9, , ,79.64,2240,90.0,0.0, 110101
,79.90,2160,2.50,3.5,27.8,80.16,3.9,-10.9, , ,80.43,2040,90.0,0.0, 110101
,80.70,1960,2.43,3.5,26.3,80.96,3.9,-10.9, , ,81.22,1840,90.0,0.0, 110111
,81.48,1680,2.15,3.5,24.8,81.75,3.9,-10.9, , ,82.01,1080,90.0,0.0, 110111
,82.28,1080,2.36,2.6,7.5,82.55,3.9,-10.9, , ,82.81,920,90.0,1.6, 111111
,83.07,920,1.81,2.2,4.5,83.34,3.9,-10.9, , ,83.60,920,90.0,3.9, 111111
,83.86,920,1.73,2.2,6.0,84.12,3.9,-10.9, , ,84.38,920,90.0,6.3, 111111
,84.64,880,1.67,2.2,6.0,84.90,3.9,-10.9, , ,85.16,920,90.0,6.3, 111111
,85.42,1000,1.73,2.2,3.8,85.68,3.9,-10.9, , ,85.94,1040,90.0,2.3, 111111
,86.20,1040,1.73,2.2,5.3,86.46,3.9,-10.9, , ,86.72,840,90.0,0.0, 111111
,86.98,800,1.81,2.6,16.5,87.24,3.9,-10.9, , ,87.50,840,90.0,-2.3, 111111
,87.76,840,1.94,2.6,11.3,88.02,3.9,-10.9, , ,88.28,840,90.0,-3.9, 111111
,88.54,800,1.81,2.6,15.8,88.80,3.9,-10.9, , ,89.06,800,90.0,-3.1, 111111
,89.32,840,2.01,2.6,12.8,89.58,3.9,-10.9, , ,89.84,880,90.0,-0.8, 111111
,90.10,880,2.01,2.6,8.3,90.36,3.9,-10.9, , ,90.62,880,90.0,0.0, 111111
,90.88,880,2.01,2.6,9.0,91.15,3.9,-10.9, , ,91.41,880,90.0,-2.3, 111111
,91.67,880,1.94,2.6,9.0,91.93,3.9,-10.9, , ,92.20,840,90.0,-4.7, 111111
,92.46,840,1.94,2.6,10.5,92.73,3.9,-10.9, , ,93.00,840,90.0,-7.0, 111111
,93.26,840,1.94,2.6,12.0,93.52,3.9,-10.9, , ,93.78,840,90.0,-6.3, 111111
,94.04,840,1.94,2.6,12.0,94.30,3.9,-10.9, , ,94.56,840,90.0,-3.9, 111111
,94.82,840,1.94,2.6,12.0,95.08,3.9,-10.9, , ,95.34,840,90.0,-2.3, 111111
,95.63,840,1.94,2.6,11.3,95.89,3.9,-10.9, , ,96.15,840,90.0,0.0, 111111
,96.40,840,1.94,2.6,11.3,96.68,3.9,-10.9, , ,96.94,840,90.0,0.0, 111111
,97.19,840,1.94,2.6,11.3,97.46,3.9,-10.9, , ,97.72,840,90.0,-2.3, 111111
,97.98,840,1.94,2.6,12.0,98.23,3.9,-10.9, , ,98.50,840,90.0,-4.7, 111111
,98.77,840,1.94,2.6,11.3,99.04,3.9,-10.9, , ,99.31,840,90.0,-3.9, 111111
,99.56,840,1.94,2.6,12.8,99.87,3.9,-10.9, , ,100.13,840,90.0,-1.6, 111111
,100.39,840,1.94,2.6,12.0,100.66,3.9,-10.9, , ,100.92,840,90.0,0.0, 111111
,101.18,840,1.94,2.6,12.0,101.44,3.9,-10.9, , ,101.69,840,90.0,0.8, 111111
,101.96,840,1.94,2.6,10.5,102.21,3.9,-10.9, , ,102.47,840,90.0,0.8, 111111
,102.73,840,1.94,2.6,10.5,102.99,3.9,-10.9, , ,103.25,840,90.0,-3.1, 111111
,103.52,840,1.94,2.6,12.0,103.79,3.9,-10.9, , ,104.05,840,90.0,-5.5, 111111
,104.32,840,1.94,2.6,12.8,104.60,3.9,-10.9, , ,104.85,840,90.0,-4.7, 111111
,105.11,840,1.94,2.6,13.5,105.37,3.9,-10.9, , ,105.63,840,90.0,-2.3, 111111
,105.89,840,1.94,2.6,11.3,106.15,3.9,-10.9, , ,106.41,840,90.0,-0.8, 111111
,106.68,840,1.94,2.6,10.5,106.93,3.9,-10.9, , ,107.19,840,90.0,0.0, 111111
,107.45,840,1.94,2.6,10.5,107.73,3.9,-10.9, , ,107.98,840,90.0,-3.1, 111111
,108.25,840,1.94,2.6,11.3,108.50,3.9,-10.9, , ,108.77,840,90.0,-4.7, 111111
,109.03,840,1.94,2.6,12.8,109.29,3.9,-10.9, , ,109.55,840,90.0,-2.3, 111111
,109.81,840,1.94,2.6,11.3,110.06,3.9,-10.9, , ,110.32,840,90.0,0.0, 111111
,110.59,840,1.94,2.6,10.5,110.85,3.9,-10.9, , ,111.11,840,90.0,1.6, 111111
,111.38,840,1.94,2.6,10.5,111.64,3.9,-10.9, , ,111.91,840,90.0,1.6, 111111
,112.17,840,1.94,2.6,11.3,112.43,3.9,-10.9, , ,112.69,840,90.0,-1.6, 111111
,112.95,840,1.94,2.6,11.3,113.21,3.9,-10.9, , ,113.47,840,90.0,-3.1, 111111
,113.73,840,1.94,2.6,11.3,114.00,3.9,-10.9, , ,114.26,840,90.0,-1.6, 111111
,114.52,840,1.94,2.6,11.3,114.78,3.9,-10.9, , ,115.04,840,90.0,0.0, 111111
,115.31,840,1.94,2.6,10.5,115.57,3.9,-10.9, , ,115.84,840,90.0,2.3, 111111
,116.10,840,1.94,2.6,11.3,116.37,3.9,-10.9, , ,116.62,840,90.0,3.1, 111111
,116.88,840,1.94,2.6,10.5,117.15,3.9,-10.9, , ,117.41,840,90.0,0.0, 111111
,117.68,840,1.94,2.6,11.3,117.94,3.9,-10.9, , ,118.20,840,90.0,-1.6, 111111
,118.46,840,1.87,2.6,12.0,118.72,3.9,-10.9, , ,118.98,840,90.0,-3.9, 111111
,119.24,840,1.94,2.6,12.8,119.50,3.9,-10.9, , ,119.76,840,90.0,-1.6, 111111
,120.03,840,1.94,2.6,11.3,120.29,3.9,-10.9, , ,120.55,840,90.0,0.8, 111111
,120.81,840,1.94,2.6,11.3,121.07,3.9,-10.9, , ,121.33,840,90.0,1.6, 111111
,121.59,840,1.94,2.6,10.5,121.85,3.9,-10.9, , ,122.11,840,90.0,1.6, 111111
,122.37,840,1.87,2.6,11.3,122.63,3.9,-10.9, , ,122.92,840,90.0,-2.3, 111111
