Results 1 to 7 of 7
Thread: werid sound?
    Senior Member Three Rings LIFES4's Avatar
    Aug 01 2007
    2000 S4
    Daly City
    werid sound?
    so i have this big clunking sound almost everytime i shift gears. The harder i shift the louder it is, but then i noticed its when i gas that it would make that sound. I'm thinking i need to change the diff fluid but would like to get some feedback. thanks.
    -Chipped -DV -TBB -Catback Exhaust -Intake -Short Shifter -DTS -Boost Gauge -Turbo Timer -CF Hood -Springs -20% Tints -CC -Red Calibers -Smoked Tail Lights -12" Sub
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    Re: werid sound?
    does the shifter move while it happens?
    sounds like the rear diff mount is bad..
    could even be a trans/engine moutn
    do you have an upgraded snub?
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Veteran Member Four Rings 1997gtx's Avatar
    Sep 14 2006
    14 GLI
    Re: werid sound?
    Sounds like motor mounts to me ...
    --Adam
    Have questions? E-mail me.
    Sep 17 2008
    2001 Audi S4
    Mary Land
    Re: werid sound?
    i had a similar version of this, didn't seem as bad as what your saying (wasn't constant, but it happened), but I ordered motor/trans/snub mounts from 034 since I was going to anyway. Should have em in on Saturday or Sunday, ill let you know if it changes anything for me.
    Aug 01 2007
    2000 S4
    Daly City
    Re: werid sound?
    ok so i'm going to buy some snub mounts and see if it gets any better. thanks
    Sep 14 2006
    14 GLI
    Re: werid sound?
    You have just one snub mount, and that shouldn't really help with the problem you're describing, to be honest.
    --Adam
    Veteran Member Three Rings Matt Danger's Avatar
    Jun 04 2007
    B5 S4
    ROC NY
    Re: werid sound?
    Before you go spending money blindly get the car up on a lift and check all the mounts front to back.
    770r B5S4 home built & tuned
