Results 1 to 3 of 3
    Veteran Member Four Rings NorCal1.8T's Avatar
    Los Angeles, CA
    Need to pass smog..help me!!!!
    So i have a CEL and i cant pass smog. We Vagd the car yesterday and came up with these codes. Some are not as important but i want to fix everything while im at it, so could you guys please help me out?
    First One: 17536/P1128/004392 - Fuel Trim; Bank 1 (Mult): System too Lean
    Possible Causes
    • Mass Air Flow (MAF) Sensor faulty
    • Oxygen Sensor Control faulty
      • Oxygen Sensor(s) faulty
    • Fuel Injector(s) faulty
    Possible Solutions
    • Check Mass Air Flow (MAF) Sensor
    • Check Oxygen Sensor Control
      • Check Oxygen Sensor(s)
    • Check Fuel Injector(s)
    Second one: 18062/P1654 Which i couldnt find a code number from Ross-Tech?
    Third: 01206 Signal for Duration of Ignition Off Time
    Possible Causes
    • Ignition Switch faulty
    • Wiring between Instrument Cluster (J285) and Climatronic Control (J255) faulty
    • Instrument Cluster (J285) faulty
    • Climatronic Control (J255) faulty
    Possible Solutions
    • Check Ignition Switch
    • Check Wiring between Instrument Cluster (J285) and Climatronic Control (J255)
    • Check Instrument Cluster (J285)
    • Check Climatronic Control (J255)
    and the next couple:
    • 01039
    • 01371
    • 01372
    • 01374
    • 01370
    • 01368
    • 00991
    • 00955
    • 00956
    I know its a lot but i hope someone can help me!
    2018 Mercedes GLC 300
    Veteran Member Four Rings dualaudi's Avatar
    Dec 13 2004
    allroad 2.7t
    san diego
    Re: Need to pass smog..help me!!!!
    I'm assuming you cleared those codes. Did you check to see how many came back?
    (sold) 1999.5tqm :: gtrs, atp 3"TP, tweaked mika t3/t4 8k, adj. fpr, forge 004, MBC, neuspeed: catback exhaust, E-bay special FMIC! 9"x28"x2.75" - SOLD
    https://www.instagram.com/dualaudi/
    Los Angeles, CA
    I cleared them, the ones that came back were 17536,18062, 01206, and 01039
