Results 1 to 21 of 21
    Veteran Member Four Rings El_Chapusca's Avatar
    Jun 06 2008
    Long Island, NY
    Removing Shift Knob
    Can anyone chime in, gonna change my shifter knob but i dont wanna srew something up while removing the damn thing. TIA
    -Joey aka Chappy
    GCC Law/Rule #22 Enforcer.
    GCC: Its Serious Business
    Tastefully Modded
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Dec 19 2007
    York, PA
    Re: Removing Shift Knob
    remove shifter surround. Pull surround up and over knob. Reveal one time use clamp, remove clamp and slide knob up. Install new knob and replace one time use clamp with zip tie and tighten tight.
    Jun 06 2008
    Long Island, NY
    Thanks for the quik info guys
    -Joey aka Chappy
    Tastefully Modded
    Established Member Two Rings Pestilaence's Avatar
    Nov 21 2008
    2004 Audi A4, 2003 Yamaha R6
    Bloomington, IN
    This is the only post that I could find concerning this topic, so I thought I would bump it up; Could you guys let me know how to swap out my shifter?? The thing is, I have an automatic. I don't have a manual, so it's a lot different.
    Veteran Member Four Rings jon102034050's Avatar
    Oct 02 2006
    MN
    Quote Originally Posted by Pestilaence View Post
    here you go
    http://www.audizine.com/forum/showthread.php?t=214401
    A4 1.8TQ - RS4 Sway - Avic-D1 - Neuspeed Sports - Bilstein Sports - Joey Mod
    Nov 21 2008
    Bloomington, IN
    Hahaha, thanks. I did some more searching, and came across that thread. I had tried the same thing it seems everyone else did... just pulling up on it, but I didn't want to break anything to I stopped. I'll try harder, and let you guys know how it goes.
    Nov 21 2008
    Bloomington, IN
    Guys, I need your help once again!!!!!! I finally got the stock shifter off, but the aftermarket one I got won't work, I don't think. I got one without a button... You just have to press down on it, since it's spring-loaded. The thing that I just found out though is that the button on the stock shifter PULLS the shifting "rod" up, instead of pushing it down. Since I got a shifter that does the opposite, does anyone know how I can use it still? If not, then I will have to put the stock one back on... which brings me to my next point. The stock shifter is spring loaded as well, but it's resting position is closed, so I have to stick something inside the shifter to push the button out of the knob, THEN while holding the button out, I have to stick it back on.
    Anyway, can someone PLEASE let me know if I can still use the aftermarket shifter I bought, or how to put the stock one back on.
    Veteran Member Three Rings fitch303's Avatar
    Jan 03 2008
    Columbus, Ohio
    Anyone know where I can buy a nice wood shift knob for my a4?
    Jun 06 2008
    Long Island, NY
    wood?!?1?!?!?
    -Joey aka Chappy
    Tastefully Modded
    Nov 21 2008
    Bloomington, IN
    Yeah... that's a big negative... Anyone know how the SPP tip mod works? I found a site that sells them and it suppsedly helps for conditions like mine, but I can't find out what it is, or what it does.
    Oct 02 2006
    MN
    you should post up a pic of the one youve got. I dont know much about knobs, but is it oem or what?
    Nov 21 2008
    Bloomington, IN
    No, it's completely aftermarket... I'm at work right now, but I'll try and posta pic later tonight. As I said, it has a spring inside that would normally push down the lever inside the shifter, but since the A4 has to be pulled up, I don't see how the SPP mod would work. I probably spent about 20 minutes last night looking over pics of it, and I can't figure out how it would fix my problem.
    Dec 17 2011
    celje
    I'm trying to remove shift knob. I was expecting metal clamp, but there is a plastic and i can't remove it.
    suggestions?
    Dec 19 2011
    Colorado Springs
    Liberal application of a hammer :D
    No really, don't do that...Im just trolling lulz!
    '12 GLI EFR 7163 - '16 S3 IE Stage 2
    Feb 02 2009
    Boston, MA
    It's a retaining clip, use retaining removing clip pliers. When you squeeze the handles they pull the clip apart. It will slide off. It's hard to see from this angle but if you could look below it, it erally has a clip there.
    Dec 17 2011
    celje
    It's so easy, lol. Just didn't pull up hard enough. (turn the plastic clockwise and pull) It's all plastic no metal retaining clip there
    Sep 05 2012
    Roseville, CA
    I just pulled mine off, chopped the length of the metal tubing by 2 inches or so and twisted on this clean black knob. Took me less than 5 minutes and I like the look of it:
    http://i148.photobucket.com/albums/s...pscbce4c6e.jpg
    Established Member Two Rings A4b61.8t's Avatar
    Mar 30 2011
    poole dorset england
    Quote Originally Posted by gregoogle View Post
    Sorry to be honest, but your whole interior looks like ass;) sorry nothing of any interest to add other than that.
    Sep 05 2012
    Roseville, CA
    Removing Shift Knob
    Quote Originally Posted by A4b61.8t View Post
    Oh I know, just haven't felt like putting too much $$ into it yet! Getting there. If anyone knows of a GOOD way to refinish interior parts that would be awesome. Seen a few interior spray painting DIYs but nothing that interested me
    Sep 30 2019
    Rockford il
    This happened to me as well. I got the new shift knob. Didn't know it was a pull action but I used the adapter and a screw so I can still use the shifter well I let my room mate use my car and when I went to leave work this morning the shift knob pulled right out. Come to find out when he was putting it in gear yesterday he broke the top part of plastic part of the shifter and now I can't use the shift now I have to use my fingers to left it and get it in gear smh need to replace this part now any one know how to do it and what it's called?
