Results 1 to 21 of 21
    Oct 29 2008
    Plymouth Meeting
    GIAC chip upgrade on a stock 1.8t
    would anyone not reccomend a GIAC chip in my 03 1.8t? a local tuning shop awe tuning uses GIAC chips and it has the option to make it undetectable and you can physically remove it from the car but i heard that GIAC chips make it run a little too hard sometimes
    Veteran Member Four Rings QuattroRocket's Avatar
    Sep 01 2004
    2103 S4, 2014 Nissan Pathfinder
    Vancouver Canada
    Re: GIAC chip upgrade on a stock 1.8t
    Ive been running GIAC in 3 A4's for over 8 years and am very happy. I have run performance files, injector files and big turbo files all with great results.
    These days "chips" are actually programs flashed onto the ECU so there is no more removal issues for dealerships and service.
    Go for it and have fun.
    Some will suggest one tuner over another but in the end a local shop you trust is the best deciding factor.
    Gone but not forgotten : 2000 A4, 2002 A4, 2004 A4, 2013 S4 Premium, 2013 Q7, 2017 SQ5 Dynamic Edition
    Current Audi : 2017 RS7
    Dec 31 2006
    boston, ma
    only problem ive heard is knocking with the giac chip...personally i have apr just because i have the lockout mode and stock file for when i go in for cpo service...theres no real better chip out there...no secret to making power over the other...so go for it
    Veteran Member Four Rings chadb2434's Avatar
    Oct 07 2008
    East Texas
    GIAC is what i've been running for a few years in my 03. Night and day difference between stock and chipped. Go for it! Don't think twice!
    02 A4 3.0Q6MT
    -chad
    Veteran Member Three Rings dfresh000's Avatar
    NNJ
    Been running GIAC since early 2004 and i love it. no issues whatsoever
    '13 Monsoon Gray S4 P+ | DSG | Carbon Atlas | B&O | Sports Diff | More Fun to Come
    '14 Monsoon Gray Q5 3.0T P+ | B&O
    Senior Member Three Rings gullatec's Avatar
    Sep 10 2008
    baltimore, maryland
    I was thinking the same thing OP. Here's my question:
    Do you need a new DV for a stock car upgrading to GIAC?
    Does the increase in horsepower make any engine components fail sooner?
    How much strain/abuse does the turbo take from the increased boost?
    brandon
    USP CLUB MEMBER #119 | dolphin gray | 6SP | UNKNOWN TUNE | TT225 (sitting in a box) | podi | cupra-lip | 6000k Fogs | 20% tint | slow
    Currently: Stage 1ish
    Oct 07 2008
    East Texas
    It is recommended you get a DV before you chip, your stock one will fail..soon
    Nothing eles will be effected except your happiness of your faster car!
    02 A4 3.0Q6MT
    -chad
    Senior Member Three Rings demea's Avatar
    Jun 12 2008
    2004 A41.8q | 05 Tr. Blzr LT
    Warminster, PA
    Quote Originally Posted by gullatec View Post
    Once you chip (APR, GIAC, Revo..), you should definitely replace the stock DV. You dont need to, but is strongly recommended.
    The increased boost, not really HP makes things like hose clamps, vacuum lines and coil packs fail fairly quicker than stock. The engine, trans, turbo, SMIC, etc can take it all. It's not a HUGE increase in power, but enough to exploit points of failure.
    Just dont beat your car all the time. You'll be fine and be glad you did.
    FYI - AWE is one of the premier tuners in the greater Philly area.
    GO PHILS!
    2004 Moro Blue A4 1.8TQTip
    GIAC | Genesis | Forge | Magnaflow | RS4 | ABT | Sport | Premium | Cold | Dings mod ~ Painted lowers are overrated
    Want to see a fun coverband in the Philly area?
    Sep 10 2008
    baltimore, maryland
    Does your gas mileage go down the tubes?
    brandon
    Jun 12 2008
    Warminster, PA
    If you floor it everywhere...yes.
    If you stay out of the turbo (tough to do :)...not really.
    Actually increased some members MPG
    Makes the car more efficient. Gets to speed quicker. Doesnt make the car work as hard.
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    i've got the Stage 1+ GIAC software and absolutely love it. my MPG is significantly better now, i think i've gained about 2-3 MPG. even when i push the car pretty hard i don't see mileage any worse than when i was stock...seems like a win win situation.
    your stock engine comes detuned from the factory and simply flashing it won't hurt the engine. your little K03 turbo can put out significantly more boost than in stock form, so don't worry about causing harm. yes an upgraded DV is necessary with software, as your stock part will eventually fail.
    if you have more questions just use the search function...there is a ton of info available on this.
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
    Senior Member Two Rings NCAUDI's Avatar
    Mar 23 2008
    02 1.8t
    Charlotte, NC
    it will go up on interstate/Hwy trips.
    Veteran Member Three Rings aalipio's Avatar
    Sep 03 2008
    05 S4 V8 02 A4 1.8T
    N las vegas
    Quote Originally Posted by eclimax13 View Post
    only Problem Ive Heard Is Knocking With The Giac Chip...personally I Have Apr Just Because I Have The Lockout Mode And Stock File For When I Go In For Cpo Service...theres No Real Better Chip Out There...no Secret To Making Power Over The Other...so Go For It
    What's The Knocking From?!? Is It Normal?! I Wanna Try The Giac But I Dont Want No Damn Knocking...
    Dec 31 2006
    boston, ma
    Quote Originally Posted by aalipio View Post
    you'll have to ask people with giac...or do a search for giac knocking...im not sure what causes it, not everyone gets it either
    Apr 25 2007
    MA
    i've never had any knocking issues at all...fyi
    Oct 07 2008
    East Texas
    My either...never heard of GIAC having a knocking issue.
    Oh and BTW, Unitronic is getting big, I had their program before my GIAC and i loved it!
    02 A4 3.0Q6MT
    -chad
    Veteran Member Four Rings OneBadAudi's Avatar
    Feb 25 2008
    02 A4 Quattro, 09 Yami YZ250f
    Cape May, NJ
    I would highly recommend Giac, great software, been runnin 1+ for almost 6 months and love it..very smooth..
    02 A4 Quattro stage 1+ (Giac Tuned)
    Siemens 380 injectors
    APR R1 DV
    K&N Air Filter
    5% tint
    STACKS boost gauge W/ Podi Column Mount
    Lip Spoiler
    Complete JL Audio sound system
    Veteran Member Four Rings Turbo1A4's Avatar
    Aug 04 2008
    2002 s4 nogaro
    Jax
    ive got my 1+ and love it
    May 30 2016
    Bit late on the post but what does Stage 1+ GIAC tune on a 1.8T need?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by B5 Gang View Post
    You will need larger injectors. Genesis 380's or Bosch TT225 386's both work well.
    May 30 2016
    That's it? Excellent.
