Results 1 to 14 of 14
    Senior Member Two Rings scottns's Avatar
    Apr 10 2008
    MA, USA
    Best jack point for a floor jack?
    Getting to be winter and I'll be bolting some snows on soon. I have a full size floor jack. What's the best jack point under the car. Pretty much anyplace on a frame rail?
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    Re: Best jack point for a floor jack?
    If you look under the side to the rear of the front wheel you will see the plastic is cut away and an exposed metal rail, same goes for rear but infront of the rear wheel, that is unless your floor jack has a huge cup.
    -Kris
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    We use jackpads here.
    They can be trimmed to fit around the various side skirts on the newer b6/B7 vehicles as well.
    Floor Jack pads
    Veteran Member Four Rings EuroA4's Avatar
    Feb 12 2004
    PA-NJ
    Hockey puck works too.
    Apr 18 2008
    Jacksonville, FL
    check your manual in the section on changing a tire. it shows where you'd attach your widow-maker that came with the car. same spots, but x2 on having a small jack cup or jack pads.
    2011 Toyota Tacoma Double Cab SR5
    SOLD 10/2011
    2008 A4 Avant 2.0TQ Tip in Quartz Grey
    APR Stg 1; RS4 Rear Sway; 034 Turbo Inlet Pipe; 35% tint; 640 SWITCH mod; GROM-I2-VAGD + Proclip
    Apostrophes: how to use them Baby Jesus cries when you misuse apostrophes.
    Veteran Member Four Rings GotRS?'s Avatar
    May 18 2008
    Try this for the long term, may not work but check it out.
    http://www.audizine.com/forum/showthread.php?t=235631
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    ^^ I love you
    The usual things!!
    Resistor Install
    Veteran Member Three Rings jahciple's Avatar
    Mar 10 2008
    08b78ea42t6mtnq
    Long Beach, CA
    Quote Originally Posted by GotRS? View Post
    i like these ones better, cheaper.
    Driver: Dustin
    Projekt: Audisciple
    Gamertag: JAHciple
    Feb 16 2008
    Oakdale, MN
    Well the ones on the rs4 won't work :( we have no screws that will hold it there. So if you want to glue them on go for it otherwise they won't work. I went down to the dealer and compared my car to the rs4! :( oh well
    The usual things!!
    Resistor Install
    Jul 08 2009
    Wisconsin
    Has anyone used the yellow jack pad above? On a B7 Audi A4, does it fit on the pinch weld without cracking any of the plastic outside of the pinch weld?
    I used the widowmaker jack the other day, and it does scare me. I've heard of folks bending the pinch weld which prompts the ques. on the pad.
    DUH! an Audi
    los angeles, CA
    i never used it, but my friend has with no problem for quite sometime.
    Veteran Member Three Rings illegitimus's Avatar
    Mar 17 2009
    2006 B7 A4 Quattro Tip S-line
    Boston, MA
    Quote Originally Posted by Mike@PureMS View Post
    Floor Jack pads
    I bought some jackstand pads and they fell to shreds the first time I used them! Never again would I spend so much money on this junk. Too soft for the application. Hockey puck all the way!
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Recently I swapped out my fuel filter, and when I removed one of the underbody plastic liners, I found we actually do have real jack points, not the pinch weld but there is a large square area where you can jack up the car in the back on each side, i didn't check the front but I would assume it would be very similar.
    Apr 06 2012
    Massachusetts
    Okay ,
    I need to do wheel bearings on the front of my 98 A4. Possibly brakes while I'm there.
    So I'll be jacking the entire front of the car and placing it onto jack stands.
    Sure I know where the jack points are that are provided by Audi, for changing tires presumably.
    But I need additional points to position the floor jack so that I can lift the car onto the jack stands.
    Of course I can't place the jack stands where the floor jack is.
    Thanks
    Ken
