Results 1 to 13 of 13
    Oct 23 2008
    North Carolina
    Locks don't work
    My locks don't work at all. Both the remote and the switch on the door have no effect. no noise or anything.
    The fuse is fine. I think it has something to do with the pump, but i don't know where it is or what it looks like.
    Anyone have any pics or suggestions that could help me out?
    Thanks
    Senior Member Two Rings Audituning02's Avatar
    May 13 2008
    2002 A4 1.8T 5QM 00 Rover Discovery 2
    Maine
    Re: Locks don't work
    I'm pretty sure the power lock vacuum pump or actuator is in the right side of the trunk behind the trim panel but I could be mistaken.
    Audituning02
    Magnaflow : TP : tt 225 DV : Color Matched Lowers :
    Pearl Black Roof : USP Front : RS6 19s : Sport Suspension : Smoked Lamps : Dice Link : Black Out Grilles : 35% Tint : Rear Lip Spoiler : ZiZa Yellow Fogs : B6 S4 Front Brake's
    Oct 23 2008
    North Carolina
    I pulled out the carpet in the trunk on the right side. there are some hoses and a white box with some wires going to it. is that the pump?
    Sorry, i'm a newb
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    Quote Originally Posted by lucas.dargis View Post
    Sorry, i'm a newb
    Yes that is the CLP.
    Oct 23 2008
    North Carolina
    OK cool,
    So do you guys think that the pump could be the problem? is there anything else i should check before i replace it?
    Sep 24 2005
    always in design
    OK cool,
    It's the pump 99% sure, the implellers shatter to a milllllllllllllllllllllllllllllllllllllllleyon pieces usually after time. I went through mine at 80k, and was locked out of the drivers door for 2 months in a record snow season in Tahoe. I had been broadsided years before and never thought to check the lock cylinder with my keys m(always used the fob) and go in that way until the locking pump broke. Needless to say I had to get a new cylinder to match my keys, compliemts of the dealer who did the body work from the accident (2 years after they replaced the door).
    Oct 23 2008
    North Carolina
    Interesting.
    I opened up the pump and the impellers were fine. however some water had got on the circuit board and looks like it got shorted out.
    So i'm gonna replace the pump and go from there i guess. Thanks for the help.
    Veteran Member Three Rings dmaize's Avatar
    Jan 26 2007
    Saint Paul
    was the water your problem?
    why didn't i buy a rs4 gill when they were $60
    Junior Member Two Rings
    Oct 16 2009
    Queens New York
    Did you fix the problem?/
    Jan 26 2007
    Saint Paul
    i fixed mine, it was the propeller. i installed a new pump. i have two more if you want one. they are from 90 audis, but work great. just plug one vacuum hose and wire it up.
    http://www.audizine.com/classifieds/...t=23012&cat=53
    Veteran Member Three Rings RoadRage's Avatar
    Feb 09 2008
    '16 Allroad, '81 Vespa PX80
    Chicago
    i might need one of those. I haven't been able to use my FOB for months now. But, I am able to use the button on the drivers door to unlock and lock the rest of the doors. So maybe it's not the CLP? Anyone have any insight on that one? FOB batteries are new.
    Jan 26 2007
    Saint Paul
    Quote Originally Posted by RoadRage View Post
    Road rage, if your locks work with the button. Than your pump is fine. Its your remote. Reprogram it. And make sure your batteries are good.
    Aug 06 2007
    Oakridge, VA
    I have a new OEM dealer bought CLP new in box for sale in the class section if you end up needing it...
    Here is the link : http://www.audizine.com/classifieds/...=23730&cat=500
    Let me know,
    Justin
