Results 1 to 4 of 4
    Sep 04 2008
    Tyre Pressure Monitor
    I've only had my Audi for 2 months so please excuse my newbie question. My tire pressure light went on today. Would 28 degree weather cause this?
    Not that it means anything but during a visual inspection none of my tires look low at all? Just wondering how sensitive the pressure monitor is?
    Veteran Member Four Rings elwigglero's Avatar
    Sep 04 2008
    B7 S4 DTM, B7 A4 2.0T Ti
    Lansdale, PA
    Re: Tyre Pressure Monitor
    Check the tire pressure...using a gauge. Fill with air.
    Veteran Member Four Rings Great White's Avatar
    Oct 07 2008
    Pinarello Prince w/Record 10sp
    Raleigh, NC
    Quote Originally Posted by TheFly View Post
    This happened with me before and again 2 days ago when it started to get cold.
    Like elwigglero said, fill with air (default is 36psi) and you may need to reset the computer. Check the owner's manual, it describes in detail how to do it.
    I considered fill my tires with Nitrogen, I'm sure AZ will have an opinion on the matter ;-) Let's hear it.
    Apr 18 2008
    Jacksonville, FL
    Yes, when it gets cold, anything filled with air will "lose" pressure. No air has escaped (unless you've got a leak), it's just the laws of thermodynamics in effect. Check out the Ideal Gas Law. If the temperature goes down, so does the pressure. This is the same concept behind telling people to only fill their tires and check the pressure when the tires are cold (ie. not driven on). So, if you get the TPMS warning, break out your pressure gauge, figure out which tires are low, and fill them to the recommended pressure as listed on the back of the driver's door frame (below the latch). You're supposed to check your pressures regularly anyway, as tires naturally lose air over time (hence filling with pure nitrogen - it leaks through the rubber slower because the molecules are bigger).
    2011 Toyota Tacoma Double Cab SR5
    SOLD 10/2011
    2008 A4 Avant 2.0TQ Tip in Quartz Grey
    APR Stg 1; RS4 Rear Sway; 034 Turbo Inlet Pipe; 35% tint; 640 SWITCH mod; GROM-I2-VAGD + Proclip
    Apostrophes: how to use them Baby Jesus cries when you misuse apostrophes.
