Results 1 to 19 of 19
    Aug 06 2008
    Canadia
    got an idea for a re-worked intake system
    I was just wondering if you guys think there would be any issues doing this to a otherwise stock S4 as far as check engine codes are concerned
    the idea is to get a 3-1 FMIC, re-locate the MAF to the single charge pipe coming off the new intercooler and mount a BOV in front of the MAF (or possibly two DV's after the MAF) and then put two air cleaners in the stock SMIC locations to give you a true cold air intake.
    my idea is basically to reduce the distance the air has to travel to the turbo and the temperature of the air by the time it reaches the turbo to reduce heat-soak and turbo lag and ultimately maximize performance.
    any thoughts?
    Active Member Four Rings
    Dec 11 2006
    Boston
    Re: got an idea for a re-worked intake system
    ....put the crack pipe down.
    the maf has to go before the turbo. placing the maf of the intercooler would be post turbo.
    Aug 06 2008
    Canadia
    Quote Originally Posted by deb38 View Post
    The maf only measures air that actually enters the engine (as does any MAF sensor) as long as you don't change that (which my idea does not) there is no issue with the maf sensor being located after the turbo.
    the kinds of issues i am talking about are things like the maf temp sensor and the IAT sensor having the exact same reading or some kind of issue with the maf being under more vacuum under WOT than it is in the stock system.
    Veteran Member Four Rings HighDesertAudi's Avatar
    Mar 09 2005
    NorCal
    Research blow-by MAF setups
    Previous Audi's
    1999 Audi A4 1.8T Quattro 5spd Laser Red
    2000 Audi S4 6spd Nogaro
    1990 Coupe Quattro 5spd Lago Blue
    2000 Audi S4 6spd Laser Red
    2004 Audi S4 6spd Dolphin Gray
    2004 Audi A4 6spd Brilliant Black
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    True^
    or "blow through MAF"
    Quote Originally Posted by MacDaddy View Post
    very false.
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Veteran Member Four Rings GURUMAN's Avatar
    Mar 13 2007
    2.9L PTE 6766 1000 Bhp single Monster !
    Montreal
    Pretty popular mod in the dsm world, but they take a GM Maf wtithc was built for that. They use a Maff translator to alter the signal.
    GURU energy drinks
    www.guruenergy.com
    10.58 @ 140.17 mph
    10.51 @ 137.56 mph
    http://www.youtube.com/watch?v=1kG98vSWkT4
    WATERFEST 15 RUN 10.92 @ 133.55 mph
    Aug 06 2008
    Canadia
    false how? what is the maf sensor doing then? saving kids in africa?
    Aug 06 2008
    Canadia
    Quote Originally Posted by GURUMAN View Post
    has it ever been done on an audi?
    Mar 13 2007
    Montreal
    Never seen it yet
    GURU energy drinks
    www.guruenergy.com
    10.58 @ 140.17 mph
    10.51 @ 137.56 mph
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    a lot of nissan guys swap to a blow through as well.
    i assume it wouldnt be that hard with a standalone.
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Apr 11 2008
    00 s4 90 crx
    High Point, NC
    LOL! Look at it this way. The maf on our car is setup to meter air before it is compressed. Putting it after the turbo would make it see compressed air, so you would need software changes(and most likely a different maf sensor/housing) to compensate. As others have said, its a pretty popular mod on other cars but ive never seen it done on an s4. If you have a decent knowledge with electronics and the ability to change the maf signal at the ecu, as well as ALOT of time on your hands then i say try it out. Just dont keep high hopes for figuring it out lol
    2000 Brilliant Black S4
    -DNA Catback, Piggies, Darintake w/ITG panel filter, 710n's, 034 TBB, 034 F hose, Vast clutch, JHM shifter & bushings, Vogtland/Koni's, Hotchkis Sways, ECS 12.5mm spacers
    2010 Honda Civic Ex Sport Auto
    -Stock daily driver/panty dropper
    2014 Fiat 500 Sport
    -Stock cone dodger for now. Suspension coming soon.
    Veteran Member Four Rings JMTx86's Avatar
    Oct 03 2005
    It could be done, rescale the maf anyone?
    00 b5 s4 Single turbo
    1969 Chevy Nova 396 (Full resto, completed in 2016)
    1969 Chevy Camaro 454 (built 454/th400, body is a work in progress)
    11 Chevy z71 5.3 shop truck (Vortech V2 build in progress)
    Dec 11 2006
    Boston
    The question is why..
    The path from turbo to intercooler to throttle body is not very far. It isn't as if there is an abundance of lag. I just don't see the extra labor and work involved, just for shorter distance.
    Oct 03 2005
    If you reduce piping on the intake side you can get the turbos to spool faster?
    Veteran Member Three Rings MiniRS4's Avatar
    Aug 11 2005
    /\/\ BIG 2nd!!!
    stick w SMIC, FMIC 2-2 / 2-1, or dual FMIC.
    3-1?!?!??!?! bhuahahahhaahha. i love this place!
    Sep 17 2006
    SLC, UT
    your sensor(THE ONE ACTUALLY IN YOUR CAR) is far too fragile to withstand higher temps in the first place.
    also, you will be changing the amount of air the maf is designed to see. compresed air vs non compresed air. DUH!
    IF you can swap in a blow through maf sensor to yours and get the ecu to 1)recognize it. and 2) read it at a rescaled rate, THEN it will work.
    but it's going to take a whole lot of time/research.
    and for what?
    so you can runzz a sweet BOV? go PSSSH pSSSSH!!?
    Quote Originally Posted by JMTx86 View Post
    BARELY. if that. if you had a 10' intake tract before the turbo, and reduced it to 1", you might gain 50rpms of spool time.
    but this is the dumbest reason yet. as the S4 doesn't even have lag in the first place. and if you were to put turbo's on the 2.7t where lag was present, you would be running SEM, which would do without the MAF anyways.
    there, i proved you guys all wrong. i didn't want to. but you guys just wouldn't listen to, "no", "it wont work", "there's no point" as other's have stated also.
    have a nice day
    Current:
    Previous:
    Oct 03 2005
    *edit* NVM
    Aug 06 2008
    Canadia
    well, it kinda got angry, but oh well, at least i got the input i was looking for eventually.
    Looks like if i can compensate for a denser amount of air passing through the maf it would work fine (maf sensors may have a shorter lifespan)
    all it really was is an idea I wanted to throw out there out of curiosity, i actually have no plans to modify my S4 unless its something i can do for free (porting the turbos, piggie pipes, etc)
    Veteran Member Four Rings revhards4's Avatar
    Feb 14 2004
    Michigan
    The best thing to do is throw the MAF in the garbage and figure out a way to change the programming for a 3 bar GM MAP and call it a day
