Results 1 to 39 of 39
    Veteran Member Three Rings sdjeff's Avatar
    Jun 04 2008
    B7 A4 2.0t, Dino 246 GT
    RSF san diego
    Depos clear cornered (NOW WITH INSTALL PICS)
    I just got my Depos on monday. My first step was clear cornering them. The process was basically the same as the OEM lights. Saturday I will be installing them on the car so i will update the pictures. The quality of the lights is great but the adjuster for the projectors sucks.. no gripes with anything else. Anyways, can't wait to get these on the car
    Veteran Member Four Rings Doctor's Avatar
    Jun 02 2008
    A4 B7 20vt Quattro,Golf MKV GT
    Greece
    Re: Depots clear cornered
    Mmmm...they seem beautiful...Way to go man :)
    DUH! an Audi
    los angeles, CA
    looks good! man i wish i could afford these =P
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    they look good but I bet the internals are made of different materials than OEM. So how you baked and resealed after taking out the cap?
    Jun 04 2008
    RSF san diego
    Quote Originally Posted by Doctor View Post
    Thank you my friend
    Quote Originally Posted by nsmith12 View Post
    Not sure what you are asking.. but i baked them for about 8 minutes at 200 degrees. I tried 5 minutes but it wasn't quite long enough. For resealing i put the lenses back on, put the clips on, and than popped them back in the oven for the same amount of time. Like i said, basically the same way as the OEM lights.
    Veteran Member Four Rings redlabel81's Avatar
    Nov 24 2007
    A4 1.8TQ 2005.5 + A6 1.8T 1998
    Tromsoe, Norway
    Looks sweet! Can't wait to see them on your car.
    Your oven needs some Mr.Muscle.....
    Life is too short to drive ugly cars!
    Phantom Black B7 A4 1.8TQ Avant
    //BSR PPC stg 1, 98 Oct//BSR cat back//S-line front rebuild//S-line suspension//Supersport loweringcaps//Votex valence//S4 doorblades//RS4 mirrors//S-line roofspoiler//S-line door sills//LED interior//Hoen fogs//mTec 6000k HID//RNS-E//S4 grill//MMR HR4//H&R 8mm//Dectane HL//LED licenseplight//Euro RS4 steering wheel//Sonniboy "Tint"//RS4 rear sway//
    Jun 02 2008
    Greece
    Basically the same process as the OEM ones...
    As for the oven, hahaha a pure bachelor's oven...
    Nov 24 2007
    Tromsoe, Norway
    ^^ true true!
    So you don't add some new selant?
    Jun 04 2008
    RSF san diego
    Its college what do you expect?
    No sealant added.. it came with quite a bit. I didn't feel like there was a need to add anymore.
    Veteran Member Three Rings felondnb's Avatar
    Jan 12 2008
    London, UK
    they look good - i was considering doing this... however, i'm trying not to spend more money on the car at the mo!
    i have my original headlights (with orange lenses) sat at home so i may take them apart, paint them black & get some B8-esque LEDs on the go.
    be good to see yours fitted.
    Phantom Black Audi A4 2.0T FSi Quattro S-Line Special Edition
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    Since you had them apart did you see any way to remove the rings to paint them with high temp black? I know you can't remove them or you'll get a bulb out, but painting them black will do the same thing. Also wondering if you can remove the reflector angel and keep the projector if it would cause bulb out as well, having both is too bmw for me.
    -Kris
    Veteran Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    2014 BMW M235i 6MT, 2010 Audi S4 6MT
    Toronto, Canada
    Just a tip - try preheating the oven to 350, then shut if OFF before putting the lights in.
    Leave them in for 15 mins, remove and you'll have no trouble at all separating them and as well, there's no chance of melting the plastic since the oven is off you're not actually 'baking' them.
    Also, USE A TOWEL of some sort instead of just resting the actual light housing on the grill of the oven itself. I'm surprised it didn't leave any indents or grooves from the rack based on how you did it.
    As a reference, I've done over 35 sets of lights for different vehicles on different forums but the basic principle is always the same.
    Jun 04 2008
    RSF san diego
    Quote Originally Posted by CONTROL ONE View Post
    Thanks for the tips!
    Quote Originally Posted by IceMole View Post
    They don't seem to be removable.. i played around with them a little bit. It would be easy to tape off and paint though. I haven't figured out what i am going to do because i certainly don't want the halo's lit. I'll keep the thread updated when i install them
    Veteran Member Four Rings p1nk50ck's Avatar
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    Re: Depos clear cornered
    would you mind taking pics of the standard halogen headlight beam and the beam from these (before and after)?
    i've seen a couple on this forum, but the more the better. most of the ones i've seen are projecting onto a garage door or something. something that shows the actual light on the road would be great. my eyes aren't that great, and my night vision is terrible (even with glasses). i wouldn't want to downgrade the light output just for nicer looks.
    Jun 04 2008
    RSF san diego
    Quote Originally Posted by p1nk50ck View Post
    Will do. I have a drop in HID kit at the moment so it will be brighter than standard halogens, but the beam will be the same.
    Deactivated Three Rings
    Dec 30 2004
    Palo Alto
    Looking good, glad you like them.
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    Quote Originally Posted by sdjeff View Post
    nice. that's actually the combo that i was looking into. from what you can see, does it look like there will be a convenient mounting place for the ballasts?
    Jun 04 2008
    RSF san diego
    I mounted my ballasts inside my engine bay.. not attached to the headlights. You could probably mount them on the back of the headlights themselves, but you want ballasts as low as possible. They will interfere with radio reception if they are up too high (such as mounted to the back of the lights).
    Senior Member Three Rings tarunpatel's Avatar
    Jul 11 2008
    Surrey, B.C.
    Lets see pics of them on the car and I wanna see pics of angel rings~!~
    Oct 20 2008
    B7 A4 2.0
    Jax Fl
    i would like to see a comparo pic between these and stock if you can
    Jun 04 2008
    RSF san diego
    Installed the headlights today. Overall the install was pretty easy.. it was the first time i removed the front bumper so we could have done it a little faster. Luckily i had my buddy(europa) helping me. The only place i had any difficulty was the main plug into the headlights on the depo's. They were really hard to snap in. I decided to keep the halos because they really look good in person. The cut-off definitley isn't perfect but im happy enough with them. The projectors are great quality though with a good output.
    Overall i am very happy with them. Two big for Darren from streetwerke.com for offering a great product with great service.
    Excuse the dirty garage. The lenses are also a little dirty. Comments appreciated
    Bumper off
    Beam pattern of halogens
    Installed with halos on
    beam pattern with depos
    finished
    Lights
    Jun 04 2008
    RSF san diego
    I apologize i forgot to take pictures of the beam pattern last night so the best i could do was against the garage. The lights have just as good if not better output though.
    Veteran Member Three Rings TheHeggi's Avatar
    Aug 03 2008
    05.5 2.0t A4 + 02 CBR600 F4i
    Redlands, CA
    So you have HIDS in now correct? The light output in the pics looks very good. I just got mine on with halogens and the light output is noticeably lower than stock....the beam pattern I think is better, but the fog lights add more light on the road than the headlights do...I hope HIDs will make a big difference because they're pretty dim as-is. Not quite dangerous dim, but noticeable for sure.
    05.5 DG 2.0TM FWD
    [Stasis SS][RS4 Rear Sway][APR 91][AEM intake][034 HFC][podi/stepper boost gauge][Satin Black B6 USPs][S-Line front bumper][RS4 Grille][Satin Black S4 blades][DIY Ti vinyl][DEPO projectors w/6000k]
    Veteran Member Three Rings BenGieCruz's Avatar
    Dec 25 2006
    '15 A3
    Oklahoma
    Re: Depos clear cornered (NOW WITH INSTALL PICS)
    imma get this things pretty soon!!!
    Registered Member Four Rings D.C. Designs's Avatar
    Feb 28 2008
    Many
    alexandria
    sexy
    Registered Member Two Rings
    Oct 22 2008
    "totalled" 98 chevy tahoe
    soCal
    oooowww weeeeee
    Veteran Member Four Rings AWDTURBO's Avatar
    Oct 28 2008
    '14 Allroad
    Newark, NJ
    nicee
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    nice! i like the look of only two halos alot better though
    Veteran Member Four Rings NorcalPB's Avatar
    Jul 16 2008
    Supercharged M3...sold/ Titanium B7 A4
    San Francisco
    Quote Originally Posted by supamannn99 View Post
    Agreed. Cool thing is though you can take out the bulbs for the inner rings and not get a bulb out warning.
    Sep 13 2008
    SYDNEY
    Just curious.. If you remove that orange cover, dont you get risk of moist going into healight housing? would blinker will block that moist 100%? what if you have to remove blinker for replacement in wet whether??
    Jul 16 2008
    San Francisco
    Quote Originally Posted by tyaos View Post
    Ya it'll block it 100%. The bulb twists in.
    Sep 13 2008
    SYDNEY
    Quote Originally Posted by NorcalPB View Post
    Cheers~
    Oct 09 2007
    E46 M3
    PA
    It's funny that audi didn't start the angel eyes thing, being 4 rings and all.
    Looks great!
    -Kris
    Established Member Two Rings stifler474's Avatar
    Mar 15 2008
    Santa Barbara, CA
    what did those lights come with? Ballist and everything?
    Silver B7 2007 A4 2.0T Quattro
    30% Tint
    De-badged
    Hoen Xenonmatch lights
    Clear Corner Mod
    Carbon Fiber B Pillars
    Colormatched Sidemarkers
    (H&R springs, and 19" rims soon to come...)
    Jun 04 2008
    RSF san diego
    Quote Originally Posted by stifler474 View Post
    They come with just the headlight housings. Than you swap all the bulbs out of the stock housings (halogens only) to these.
    Thanks for the comments everyone!
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    no, those pics are great. have you driven around at night with them? how's the light output?
    i read earlier how you had to mount the ballasts low, or it will interfere with radio frequencies. do you have any pics of where the ballasts were mounted? did you have to drill or was the mounting pretty straight forward?
    can you change the ring bulbs to a whiter color?
    Nov 24 2007
    Tromsoe, Norway
    ^^ I know these heads are sold with other coloroptions on ebay.de so I guess it's possible to change the color on the eyes.
    Install looks great! Good writeup.
    Jun 04 2008
    RSF san diego
    Just a warning: If you plan to CC, add more sealant.
    One of mine are letting in a tiny bit of moisture. Fortunately i have to take the bumper and lights off again anyways to adjust the beams.. they are set a bit too high.
    I would love to know if there is a VAG code to disable DLR/City lights or whatever these Halos are replacing. I like them but would like to be able to turn them off sometimes as well.
    I'll get some pictures for you later tonight or tomorrow. I didn't mount them very professionally but it will give you an idea.
    Jul 14 2008
    Nissan X-Earth
    Orem Utah
    Hey buddy, sent you an email regarding some others with moisture problems, one said they put a silica packet, the freshness packet, in the headlight and sealed it in there! They haven't had a moisture issue since. Not sure if that would really work but something to consider, that and some sweet ace epoxy!
