Got some codes yesterday and i can tell by doing some research what the probable causes might be but here they are anyway:
*P1113-h02s sensor heater resistance too high,bank 1 sensor 1
*P0300-cylinder misfire detected-random cylinders
*P0102-map(man, absolute pressure)/bard or maf/vaf sensor condition
*P1129-long term fuel trim b2 system too rich
*P1127-long term fuel trim b1 system too rich
Today there is no check engine light and no codes pulled up? Would the primary 02 sensors cause boost to completely cut out yesterday? Today the car was running fine.
I plan to change the 02 sensors,clean out the maf, and do a pressure test, is there anything I should be looking into as well? TIA
