Results 1 to 18 of 18
    Oct 29 2008
    Chicago
    How tunable will the new S4 be?
    How tunable do you guys think this 3.0 supercharged engine will be? will it be as tunable as the old 2.7 twin turbo? will it be more worth in hp than the 4.2 not considering the fuel economy?
    Mar 11 2007
    '04 G35x
    Brooklyn
    Re: How tunable will the new S4 be?
    Quote Originally Posted by crazy_deude View Post
    Superchargers are not as tunable as turbochargers, so it won't be as tunable as the 2.7TT
    The 3.0T already has more torque than the 4.2. Im sure they will also come out with smaller pulleys, which will increase boost and power.
    Veteran Member Four Rings Toast's Avatar
    Jul 05 2004
    2014 X3.5m
    San Gabriel
    i would say new pulley and tuning probably get extra 10-20%
    2010 A4 Avant
    Veteran Member Four Rings 94jedi's Avatar
    Dec 07 2004
    Oly Platform, Pendlay bar, bumpers, squat rack, rings, Prowler
    Ocean Shitty Maryland
    Quote Originally Posted by Toast View Post
    does anyone know what kind of S/C it will use? That's the big question. Depending on how much Audi leaves on the table, pulley/tune can be as much as a 30% gain.
    Then if there's a large enough market, look out for aftermarket s/c's, after coolers, heat exchangers etc. hell, if there's enough demand, I'm sure someone will have a turbo kit for it.
    The harder I practice, the luckier I get.
    - Gary Player
    Jul 14 2008
    Hong Kong
    i think the press release says Root type, whatever that is....
    Veteran Member Four Rings haus4's Avatar
    Apr 27 2008
    silver s4
    LI
    I read somewhere its a Eaton roots style charger. Roots style refers to how the actual boost is created. In this case, you have 2 cork screws that are inter meshed into each other that spin at very high speeds to move air to create the pressure know as boost into the engine.
    here is a link i could find on how a roots supercharger works.
    http://images.google.com/imgres?imgu...icial%26sa%3DG
    I know it says images.google but it works. Sorry for the poor site, but its better than nothing. The pics help alot if you have no idea of what i explained.
    as for tuning, it wont be as tunable as a b5, but it has alot more options than the 4.2 Any stock FI engine can be tuned for more horsepower. I think this will be the next "modders" car and will replace the b5 in way of tuning.
    Guess ill have to start saving. After i get to stage 3
    Veteran Member Four Rings Justincredible's Avatar
    Jul 24 2008
    chicago
    I think time and the number purchased will tell how far up the tunable list the car goes. I do how ever completely disagree with the less then the. B5 I actull think it has more potential. Here is why
    Lets look at a car to compare this with. Now if you have a car like the ford super coupe then that car was a tuning flop almost nothing available and next to nothing done performance wise. I think this is more to do with the fact that the car was very advanced for its time and not many people were ready to TUNE the ECU. So lets go to more modern day.
    The supercharged JAG is more in our league. Altho I think the S4 owners are more aggressive with the want for more speed. Hence the 10k for a supercharger and the almost 6k for the turbo upgrade for the b5. So I will also include the 03 cobra.
    with the cost of the cars almost nothing exciting is going to come out for the first 3-4 years depending on the mood of the purchaser. But the list for mods is huge
    1 you have the plain chip
    2 then you have the pullie for the supercharger
    3 of corce the exhaust and Dp's
    4 then you have the heat exchanger for the supercharger
    5 then the actual modification of the supercharger it self
    6 shifters obviously
    7 brakes
    8 over time a bigger supercharger
    9 fuel system upgrade at some point
    So really it is on the same scale as the B5 it is just going to be up to the crowd that buys the car to drive the development of the aftermarket. But mod wise there is just as much on the table as the turbo cars
    Nov 19 2005
    Pair of (. )( .)
    10 bigger intercooler
    -Andrey
    Stanced and Tuned Brilliant Black RWD C5 A6 2.7T 6MT
    Veteran Member Four Rings ultra's Avatar
    Apr 12 2007
    13 Allroad
    San Antonio,TX
    all sounds like fun to me
    Eurocode
    2013 Allroad Volcano Red, Eurocode goodies
    2018 SQ5 Florett Silver S-Sport package
    Feb 17 2004
    Sterling, VA
    the supercharger should be an Eaton VTS series. Either the 1320 or the 1640.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Veteran Member Four Rings Beelzeebub's Avatar
    Oct 08 2008
    B7 S4
    launch control, race mode, etc.
    Veteran Member Four Rings Tanner's Avatar
    Markham, ON
    Wonder if the possible upgrades for the B8 S4 would be something "similar" to what is possible with the Ford F-150 Lightning. Yeah it's a truck but you get the idea. 700hp at the wheel for that truck after some upgrades from Whipple!
    Mike
    Feb 17 2004
    Sterling, VA
    Quote Originally Posted by kievskiy View Post
    That will be very tricky since the 3.0T features a liquid-to-air intercooler built into the intake manifold. There is a separate portion to feed each head.
    Brett - Moderator
    Issue?: email me.
    Veteran Member Four Rings initiala4's Avatar
    Feb 24 2004
    Land of the smiles
    The problem would be going into the ECU
    2019 B9 RS4 - O.CT Tuning Stage 1 | Wagner Intercooler / Radiator | Ohlins R&T DFV | 034 Motorsports Dynamic + Sway bars | 034 Motorsports Transmission mount | Ignition Projects Coilpacks | HHC Rear rotor upgrade 370mm + Endless MX72 brake pads
    Formerly - 2003 Audi B6 A4 1.8T QM, 2013 VW Passat Variant 2.0 TSI
    Nov 19 2005
    Pair of (. )( .)
    interesting point, i never thought of that. i guess time will show, cause i am really looking into getting an s4 at some point, i drove b8 a4 and the interior is very roomy compared to b7 imo.
    Quote Originally Posted by Daft View Post
    -Andrey
    Veteran Member Three Rings B. Rock's Avatar
    Jul 27 2008
    09 3.0T A6 Avant
    Roots? Really? I would have thought Audi would move more towards the centrifugal type w/ less power drain and more turbo-like response. Either way, swap out some pulleys, dabble with the ECU and the exhaust/intake, and some extra power will be made. Heck, some high flow heads would be nice too. I'd say it's too early to tell which will make more power - b8 or b5, but ultimately total power depends on the $$$ supply and the strength of the block.
    09 A6 Avant 3.0t
    06 E350 4x4 Cummins swapped
    01 WJ rock toy
    Markham, ON
    Apparently, the word is that Audi had two engines being developed for the new S4. One turbocharged and one supercharged. In the end both worked well, but with the economics and the emissions we have today, the supercharged engine had the upper hand. Audi will still use turbos, but for the "bigger" applications when you need 400+ hp.
    Reviews of the new S4 have been very favorable. No turbo lag, torque everywhere (curve is similar to that of a turbo engine but of course it's done by the ECU).
    Mike
    Veteran Member Four Rings audirs's Avatar
    Mar 22 2005
    Kitchener, Ontario
    if someone twin charges this engine, id think it would be as good as the 2.7 if not better (yes i said it!)
    Q5 3.0T S-line
    VW Tiguan R-Line
    A6 2.7T AWE Stage 3
    Coupe Quattro
