Results 1 to 4 of 4
Thread: How to tell...
    Active Member Four Rings 00s4slvr's Avatar
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    How to tell...
    Hey so when i start up my car my vaccum in park and nuetral is at 20, but when i put it in a gear (drive or reverse) in drops to 18...? is this normal?
    How can i tell if i have a vac/boost leak?
    Veteran Member Three Rings ThePaintballGuy's Avatar
    Mar 14 2007
    Phoenix Arizona
    Re: How to tell...
    Yeah thats normal because your engine has a very slight load on it when you do that so it decreases the vacuum. I am assuming you have a tip?
    JOsh
    Veteran Member Four Rings haus4's Avatar
    Apr 27 2008
    silver s4
    LI
    Re: How to tell...
    yes that is normal. if you had a leak, ur boost wouldnt build to the max it is set at, or your vac wouldnt be as low as 18. it would be higher.
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Re: How to tell...
    i have a tip and thanks.
