Front Rotor: 321x30
Rear Rotor: 256x22 *rear does not fit the B6 hub*
B6 A4 1.8t
Front Rotor: 288x25
Rear Rotor: 245x10
B6 A4 3.0
Front Rotor: 312x25
Rear Rotor: 255x12
B6 S4
Front Rotor: 345x30
Rear Rotor: 300x22
B7 A4
Front Rotor: 320x30
Rear Rotor: 288x12
B7 S4
Front Rotor: 345x30
Rear Rotor: 300x20
Here's all the part numbers I have for the S4 brake upgrade...
8E0 615 125 C: 07 Carrier [x2]
8E0 615 123 C: Caliper [left]
8E0 615 124 C: Caliper [right]
8E0 615 269: spring [x2]
4D0 698 647: Pin [x2]
Porsche 996 & Porsche Boxter
Rear Caliper to B6 Front???
Will require custom brackets to mount the caliper to the hub. Will also require custom brake rotors.
VW Touareg
FRONT:
1LB - 308x29.5mm rotors with single piston floating caliper, generally should be only on the R5 model. Made by ATE.
1LE - 330x32mm rotors with 2 piston calipers. Usage unknown at this time. Made by Brembo.
1LC - 330x32mm rotors with 3 piston calipers. Was used on V6 and V8 model in North America. Made by Brembo.
1LF - 350x34mm rotors with 3 piston calipers. V10 model. Made by Brembo.
Rear:
1KE - 314x22 rotors with single piston floating caliper, R5 model. Made by TEVES.
1KQ - 330x28mm rotors with single piston caliper. Usage unknown at this time. Made by Brembo.
1KF - 330x28mm rotors with 2 piston calipers. Believed to be used on V6 and V8 North American models. Made by Brembo.
One other note, each model takes a different set of brake pads. Front calipers will bolt on with use of the correct brake rotor and hardware kit. You can purchase Mercedes ML55 front rotors or B6 S4 front rotors to use with the 350mm front calipers. 330mm front calipers will work with Mercedes C230 Sport rotors with modification.
Porsche Cayanne
Front Rotor: 350 mm X 34 mm
Rear Rotor: 330 mm X 28 mm
Footnotes:
*Unless noted otherwise, you will need all parts including backing plates and brake lines along with the actual braking components.
*B7 A4/S4 Calipers bolt up the same as the B6 S4, but the B6 S4 calipers are externally slightly smaller.
so what are our choices? I am trying to compile a organized guide for the forum of what OEM configurations are available and if they're worth the effort.
does the A8 calipers work for the rear? I searched and all i could find is fitting the rear A8 rotor using A8 carrier with an S4 caliper.
its all very confusing but it seems that all the calipers are the same, but the rotors and brackets are different?
is it possible to use the whole A8 setup?
