Results 1 to 20 of 20
Thread: GB on pistons?
    GB on pistons?
    so im in the market for some pistons, and i was shopping around and got some pricing avaliable from some very reputable makers
    i can get you guys:
    arias brand
    82.5mm bore
    TOOL grade floating wrist pins
    nitride rings
    4-5 week lead time
    in the 1k range
    or through ross, and wiseco prices may vary slightly
    all very good manufacturers.
    arias is my #1 pick for our applications since they have already made pistons for the 2.7 already, called up je and the sales man was a dick so no thanks, service is worth alot in my eyes
    if there is enough interest i can help you guys out
    if not i will be ordering my own by myself
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Re: GB on pistons?
    I would go with JE's (personally speaking).
    If you need a set of pistons send me a PM.I can also organise a GB np if there is enough interest.
    Senior Member Three Rings 02alltoad's Avatar
    May 27 2008
    04 S4,Allroad,00 911,00 a6 4.2
    Arvada, Colorado
    Re: GB on pistons?
    im interested but i was going to go 83.0mm at 9.0:1 cr
    Re: GB on pistons?
    the prices i got was for all pistons same dimension and cr, since they can use the same blueprint. i was going for 81.5 or 82.5 bore depending on my cylinderwall conditions
    je makes great pistons, so does arias, cp, wiseco, and ross
    all are good companies and have been proven and trusted time and time again. arias is big in the domestic and import scene, they are race proven 9000+rpms, and will more hp/cylinder than any s4 can put down
    isaam from 034 is a great guy to deal with, i only had 100% satisfaction w/ his services, you can give him a call or call up the pistons manufactures directly and have them recommend one of their bigger distributors, you will find pricing varies alot depending on who you go through. just an example i got 3 quotes from 3 distributors from wiseco and a range of price ~$200 difference.
    lead time will be longer if the manufacture doesnt have blueprints for your application
    the manufacture im going with has made them already but still has a longer lead time just due to the shear volume of business they do. do what you like
    why 9.0? stock is 9.3 or 9.2 or something, cant remeber off the top of my head, i was measuring my shortblock and for going 3mm over .... i dont think i would go that far, but whatever floats your boat, i want more meat between my walls
    heres a really crappy pic of the block, though i dont think it would help you at all, just take your own measurements and see how much meat is left 1.5mm added each side
    Account Terminated Four Rings
    Aug 06 2007
    audi, subaru, dodge, ford
    Truckee, CA
    Re: GB on pistons?
    JE is crap, i have never once custom ordered pistons from them and had them show up with the correct CR
    CP or Mahle or bust
    May 27 2008
    Arvada, Colorado
    Re: GB on pistons?
    Quote Originally Posted by goohead View Post
    i was looking at 83.0mm for the displacement, stock is 81.0mm stock us comp is 9.3:1 and the rs4 9.1:1 the block i have the pistons made contact with the walls pretty good so it will need to be bored. a friend of mine said he had a costomer bore his out to 83.5mm with rs6ss turbos and its been fine for almost 2 years so i figured 83 would be ok and as for the comp ratio i want a bit more low end im not looking for a high boost race engine so i thing staying close to the stock raito would be best for me
    May 27 2008
    Arvada, Colorado
    Re: GB on pistons?
    i was just wondering if this is a dead subject, i think ive settled on 82.5mm bore and 9:1 cr pistons
    Feb 26 2006
    Earth
    Re: GB on pistons?
    Quote Originally Posted by JaredVL View Post
    CP or Mahle or bust
    You probably dealt with a shitty rep
    Both Justin ,Dom,Panyotis and others run custom JE pistons all Built to there specs.
    Account Terminated Two Rings
    Nov 29 2008
    Washington michigan
    Re: GB on pistons?
    arias pistons are top quality je and cp is garbage
    Feb 26 2006
    Earth
    Re: GB on pistons?
    Quote Originally Posted by slowslvrs4 View Post
    Speaking for personal experience of internet banter?
    Nov 29 2008
    Washington michigan
    Re: GB on pistons?
    personal experience on my race bike i have had all the above pistons in it.
    Feb 26 2006
    Earth
    Re: GB on pistons?
    Did you take that up with JE?
    Nov 29 2008
    Washington michigan
    Re: GB on pistons?
    yeah and the rep was a real hard head and said i probally built it wrong.
    Feb 26 2006
    Earth
    Re: GB on pistons?
    Not trying to insult you but that is always usually the case.Tolerances are too tight and the piston gets "pinched" and fails.I have had nothing but success with JE pistons and the same can be said for all of my customers
    Nov 29 2008
    Washington michigan
    Re: GB on pistons?
    Hey I had no problems with the arias so I'll leave it at that. The je's would clank untill fully warmed up.
    May 27 2008
    Arvada, Colorado
    Re: GB on pistons?
    i have HEARD that je's do knock in the 2.7 ive only heard that, how much are the arias?
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: GB on pistons?
    Quote Originally Posted by 02alltoad View Post
    thats all about clearance... my wisecos did in my B6 because my machine work was bad... I think on some of the piston sheets they recommend too much clearance.
    - Clint
    May 27 2008
    Arvada, Colorado
    Re: GB on pistons?
    good point, my machine shop mesures each piston and bores the hole to its size, i finally have the money for pistons so i would like to get as many opinons/experance as possible befor i buy a set
    Re: GB on pistons?
    piston slap has alot to do with clearance, doesnt effect performance, our engines are undersquare, so rod angle is pretty low due to the rod length so it enters, exit the bore not at excessive angle. piston slap is much worse on some other engines i seen, you will notice it on almost any aftermarket piston period. there are offset wrist pins as well to give more rod angle on power stroke and not on comp and exh stroke.
    some people run alot more boost or plan to add nitrious and want looser clearance, i mean you can go full race spec but will need to rebuild sooner, i just stick to the rule of thumb or mid ways or loose side of manufactures recommendations and be done with it. my stock internal clearance was really on the loose side, and there was still crosshatch marks so from the factory there plenty clearance.
    or ask your engine builder if you dont any better
    02alltoad - let me know i can get you a set @ your specs for $1050 including rings and wrist pins
    the nitrided rings and tool grade thick wall wrist pins as well are best you can get. the rings especially since they have longer life than moly rings, if you dont know nitride rings are very popular in japanese cars from the factory thats why their engine can last longer without rebuilds vs americans, etc even when beaten on. google it up if you want more info
    lead time is 4 weeks
    once i place the order you can check with arias directly on status realtime yourself, or i can check for you through my guy
    let me know
    hit
    Veteran Member Three Rings poopypants's Avatar
    Jun 18 2007
    '64 LeMans, '00 CBR929RR
    Perris, CA
    Re: GB on pistons?
    In for GB. I need 84.5 mm (8 total) thanx
    "The Constitution of most of our states (and of the United States) assert that all power is inherent in the people; that they may exercise it by themselves; that it is their right and duty to be at all times armed."
    - Thomas Jefferson
