Results 1 to 18 of 18
Thread: overboosting?
    Oct 19 2008
    South Florida
    overboosting?
    Hey guys im new to the forums and im here posting this because I have a a major problem. First my mods, carbonio cai, godspeed fmic, apr exhaust, vmr testpipe, forge dv and apr stage 2 tune. Here's the problem my CEL is on and the code its throwing is overboosting, when I punch it in 1st or 2nd the turbo seems like its choking and in 3rd and 4th gear it seems to be almost powrless, and when im in 5th and let the turbo spool I hit fuel cut and my CEL lights up. I really have no idea why this is happening is it possible that the spring in my wastegate needs to be replaced?
    Oct 19 2008
    South Florida
    Re: overboosting?
    Im almost thinking that it cud be the tune?
    May 20 2004
    More cars
    Never Land Ranch
    Re: overboosting?
    could be! is your car covered under warranty?
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    AMD/EPL Tial 605 B5 S4 SOLD
    Nov 12 2007
    Grand Junction, CO
    Re: overboosting?
    sounds like it could be a PCV or incorrectly installed DV, or maybe even your fuel rail or fuel pump. I think it will take quite a bit of trouble shooting to figure out what is wrong.
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Re: overboosting?
    what's the problem code if you please can provide that.
    Veteran Member Three Rings Zebman's Avatar
    Dec 25 2007
    '06 A4, 08 R6s
    Morgantown/Hurricane, WV
    Re: overboosting?
    Do you have a boost gauge? If not, you need one by now with your mods.
    2006 A4Q 6MT Arctic White - StageII++
    STaSIS SS Coilovers, EVOMS Intake, APR 93, OZ Ultraleggeras 17x8, APR Exhaust w/034 HFC, GSG Intake Pipe, AWE Front Mount, APR HPFP.
    2008 R6s
    : Racebike, don't feel like writing it all out.
    I don't get on Audizine anymore, so if you need me... sorry.
    Oct 19 2008
    South Florida
    Re: overboosting?
    I will retrieve the specific code tmw morning, the dv was installed properly im sure of it. Now what exactly is pcv?I have my podi gauge pod with gauge ready to be installed but honestly before I move further with and upgrades I want to get to the bottom of this. Im not sure if this is fuel related at all either but I cud be wrong.
    Dec 25 2007
    '06 A4, 08 R6s
    Re: overboosting?
    What? A gauge will tell you what's going on much better than any other diagnostic tool you'll find.
    2008 R6s
    Veteran Member Four Rings eMacPaul's Avatar
    Jul 26 2008
    Marysville, WA
    Re: overboosting?
    Yeah, put on the boost gauge. Then you can see what kind of pressures you're actually running in all the different gears/RPMs.
    2007 A4 2.0T CVT Cabriolet S-Line Phantom Black
    APR, K&N air filter, Podi boost gauge, chrome-stripped grille, RS4 RSB
    Smoked side reflectors & markers, smartTOP, Eibach Pro-Kit, 12F/15R spacers, ER SMIC
    Xenon match DRLs, LED fogs, city w/ fogs, S4 mirrors, red LED interior, CC, 034 HFC + Magnaflow 14829
    Oct 19 2008
    South Florida
    Re: overboosting?
    whats the pcv fix?
    DUH! an Audi
    los angeles, CA
    Re: overboosting?
    what chip you running?
    Veteran Member Three Rings Nico's Avatar
    Mar 02 2007
    Sydney, Australia
    Re: overboosting?
    Quote Originally Posted by DTMa42.0t View Post
    I doubt it is the tune. There are plenty of people who have the same setup without problems. You need to do some logs on vag-com, boost actual and specified, N75 duty cycle, fuel pressure actual vs specified.
    If your code is over boosting It wouldn't surprise me if the culprit was the forge valve, people have had problems with them being installed incorrectly.
    Mar 02 2007
    Sydney, Australia
    Re: overboosting?
    Quote Originally Posted by Zebman View Post
    Hardly........boost gauges are inaccurate and not very sensitive. VAG-COM is the best diagnostic tool.
    Oct 19 2008
    South Florida
    Re: overboosting?
    the problem started before the forge dv was installed. I installed the forge dv 3 days ago thinking that my oem dv went out. unfortunately I wont have a day off until sometime next week, but I will be doing more testing. im not familiar with the pcv problem which was mentioned earlier in the thread?
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    Re: overboosting?
    Quote Originally Posted by Nico View Post
    +1 logging
    -Kris
    Dec 25 2007
    '06 A4, 08 R6s
    Re: overboosting?
    Whatever, both are telling you boost.
    2008 R6s
    Mar 02 2007
    Sydney, Australia
    Re: overboosting?
    True, but only one can determine what is wrong with his car because just seeing what your boosting at is only part of the puzzle thats why I was recommending logs.
    Jul 04 2007
    Anchorage, AK / Chicago, IL
    Re: overboosting?
    hey sorry to thread jack, but how do you like your fmic? Did you have to remove the factory bumper support or anything crazy like that?
