All I did was take an existing intake tubing that I had laying around from my jetta. http://weapon-r.com/english/index.ph...oducts_id=5475 < that was the kit I bought. I cut the left end of the main tube (as shown on link) just before the bracket peace that sticks out. The exact length of the tube will differ due to different length of the cone filter ppl use, but the elbow angle of the tube on the left side is near perfect. The only material I bought was a silicone coupler 3"(tube side)-2 1/2"(turbo inlet side). All other parts such as 3"-3" couplers used for my entire custom intake system was re-used from the kit mentioned above, minus the K&N cone filter. Installation should be self explanatory, if you are filmier with the cone air filter install.
In terms of results: quicker turbo spool (I think), sound of spool is more evident inside the car, deeper exhaust note from out side of car and more woosh sound during air intake. Most results are minimal but noticeable. Plus the sexy factor of shiny tube vice black rubber hose.
The only thing I may change will be instead of using regular hose claps, I will use T-Bolt clamps like GSG.
I love AZ!
