Results 1 to 20 of 20
    Veteran Member Four Rings rocky.ca's Avatar
    Aug 24 2008
    Out with the old, what to get for the new
    Im inbetween getting an older 1998 or so 1.8t and building it and a 1999.5-2001 with under 75 000 miles and saving up for mods. pros and cons of both? i will have around 10 000 to play with but i have to keep it within canada so prices are going to be a bit higher
    Established Member Two Rings lanoueb5er's Avatar
    May 25 2008
    2000 a4 1.8t Q
    montreal (I mean, Canada)
    Re: Out with the old, what to get for the new
    facelift. got mine for 8500$ can tax in and I guess they are more reliable since its the end of the model-line years
    Aug 24 2008
    i found a brilliant black 2001 a4 with only 113 000kms on it, can get it for around 8-85 taxes in... dont know how long it will be on the market though
    May 25 2008
    2000 a4 1.8t Q
    sounds like a good deal if its clean and depending how much money in repairs it needs
    Aug 24 2008
    anybody else have an opinion?
    Veteran Member Four Rings lowandslow4now's Avatar
    Jul 12 2008
    Cumming, GA
    I like the DBC for my preference but with the newer ones with MAP sensors you can get software now to run MAF less if you go BT its a tough one. If I could do it again I would still go for the older ones
    Now 2001 B5 S4
    Former B5 A4, 034 Stage 3 BT, Unitronics,H&R,etc,etc
    Dec 05 2007
    Prefacelift:
    Pros
    -AEB engine
    -Many seem to adore the DBC as the DBW can have a mind of it's own at times
    Cons
    -Prefacelift exterior and many like to upgrade ot the 1-peice headlights and facelift tail lights
    -20 less hp (but I believe the 00 also has the same)
    -Older style dash console
    Facelift
    Pros
    -k03s and 20 more hp stock (01 model)
    -one peice headlights and tail lights
    -newer dash
    -flashed software
    -MAFless tunes
    -Meth kit ran off of Map sesnor
    -Diode mod
    -Knock sensors
    -fog lights
    Cons
    -Weaker block
    -I have no issues with the DBW, but many would always say the DBC has a better throttle response
    It all depends on what you want. If you just want a more reliable block, don't care about making the intake w/ MAF on a BT set up, don't mind not having fog lights, prefcelift interior and exterior, than go with the AEB. If not, then go with the 01-01.5 (AWM). Not the ATW.
    Account Terminated Four Rings
    Aug 16 2007
    Buffalo NY
    Or you could get a 1999.5 like mine and have the best of both worlds! hehe
    Veteran Member Four Rings Jibberific's Avatar
    May 22 2008
    az
    yeah the 1999.5 is the best of the B5s
    {99.5 Avant}
    Aug 24 2008
    aha! I JUST found a 1999.5 that was posted today. It has 142 000 kms on it, and the guy wants 8k for it. only thing is that it has HIDEOUS black rims (im going to tell him to keep them and put on the stockers ) which will hopefully drop the price to 7000 and "euro tails" im assuming altezzas... ugh, maybe he still has the stock tail lights. maybe i can get him down to around 6800-7000, and depending on the condition. im inbetwen this car and the other one i posted above... decisions decisions
    hey, maybe i can finally pay off the credit cards, god i hate being a student
    Oct 30 2006
    B8 A4 Avant 6spd
    Prefacelift:
    Pros
    -AEB engine
    Cons
    Facelift
    Pros
    -newer dash
    -flashed software
    -MAFless tunes
    -Diode mod
    -Knock sensors
    -fog lights
    Cons
    -Weaker block
    AEB
    Pros:
    Less emissions BS on the motor
    I never not once had a boost leak in two years of ownership .
    Big port head / intake manifold
    Prefacelift was about 150lbs lighter as a whole.
    Cons:
    Less refined interior quality / fit and finish. Over all the car is a tad louder.
    Less safe, no curtain airbags.
    AWM/ ATM
    Pros:
    Nicer interior / quality / fit and finish. When the car was stock it was eearie quiet in there.
    Safer
    Cons:
    Overly complicated emissions system (Secondary air injection, EGR, TOO many damn vacumme hoses And CONSTANT boost leaks)
    Numerous unecessary Sensors
    Smallport head / intake manifold
    Heavier due to revised interior / exterior.
    Overall I liked my old AEB better, I had that car running like a perfectly tuned clock. While my replacement has numerous teething problems. I guess I will like it more with time. And I'd Definitley would reccomend an 2001 over any year, seeing that if you ever want to big BAT setup, its really easy to stroke the motor.
    -18 718 GTS
    Aug 24 2008
    would the 1999.5 be considered pre-facelift, or facelift?
    Oct 01 2008
    Philly
    99.5..if i could go back in time i would have gotten on instead of my 01
    Oct 01 2008
    Philly
    Quote Originally Posted by rocky.ca View Post
    facelift
    Aug 24 2008
    yeah, thats what i thought, so the 1999.5 has all the benefits of both the aeb and awm/atm? seems like the most logical choice. im going to see what i can talk this guy down to :)
    Veteran Member Four Rings VTAudiA4's Avatar
    Oct 20 2007
    Why would you not want to go with a ATW engine? The bottom end is AEB while the head is ATW. Am I right?
    Active Member Four Rings burner799's Avatar
    Oct 14 2006
    Hermosa Beach/PHX AZ
    Ti.Sline: yeah my dads got shit in order
    SkunkonCrunk: i had to pay $300 and fight the city after they sprayed a bike lane on my car
    SkunkonCrunk: i hear ya, i know u guys dont get along but let bigons be bigons, or however u spell it, im at a two year
    Veteran Member Four Rings Tifun's Avatar
    Jun 21 2007
    99.5 A4, 08 Mazda3
    Indianapolis Indiana
    Quote Originally Posted by Jibberific View Post
    yeah times eleventybillion. I got my 99.5 because its the best of both worlds.
    Oct 01 2008
    Philly
    Quote Originally Posted by VTAudiA4 View Post
    because it's dbw
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Cons
    -Weaker block
    Weaker rods,not weaker block...
    The block can be taken to 800+whp no issues.More than anyone in North America will ever make (except me & Paul )
    My advice is to go with the AWM A4.Why?
    * You get Motronic ME-7 (more files available and you can run a MAFLESS software) - Perfect for GT3582R+ users
    * DBW - can remove the lag in the software and the options for larger throttle bodies are the sky.For DBC there is only 1 single DBC upgrade available.
    * Internal water pump block - allows you to really clean up the accessories down the road if you want allowing for larger custom intake manifold set ups.
    * NO AC compressor on the passenger side of the block on some models.This will allow you to run a large bottom mount turbocharger + tubular manifold.
    That is just to name a few.The AEB head is not the be all end all...the small port head is just as good,it just needs to be port matched to an AEB intake gasket.
