Results 1 to 40 of 45
    Veteran Member Three Rings 3M0RT4L's Avatar
    Jul 07 2004
    '00 AWE Audi S4, '01 3.0 WB S4, '04 Bagged/Shaved R32
    VA / DC
    Retrofit of a B6 or B7 Steering wheel?
    My B5 steering wheel is showing its age.
    Has me thinking if a paddle shifter steering wheel from a B6 or B7 S4 is able to be retrofitted to work.
    Is it possible?
    2001 RS4 Widebody
    2004 R32
    Dapper.
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    Re: Retrofit of a B6 or B7 Steering wheel?
    wow u still come on here? lol
    have seen them done so its possible and they look hott so go for it
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Veteran Member Four Rings Overboostin's Avatar
    Mar 15 2007
    New England
    I've seen a paddle shift from an rs6 retrofitted to fit in an s4.
    the homebrew'd s4
    Jul 07 2004
    VA / DC
    Nice. This gives me hope!
    Do you think its fairly plug and play?
    2001 RS4 Widebody
    2004 R32
    Dapper.
    Veteran Member Three Rings AUDILUX's Avatar
    Oct 16 2007
    B5 S4 / 335i
    My Garage: 4 door, AWD, twin-turbo Germans -
    • 2001 Midnight Purple RS4-widebody S4 (ASP Stage3)
    • 2009 Alpine White 335ix sedan
    Speed has never killed anyone, suddenly becoming stationary... That's what gets you. -J. Clarkson
    Veteran Member Four Rings wdbdy2000s4's Avatar
    Oct 08 2008
    1998 pathfinder, 2000 s4
    MA
    Will the airbag maintain functionality? Can the audio buttons be hooked up to an aftermarket nav? or just the b6/b7?
    Mar 20 2008
    Italy
    It's not a direct fit.
    b7 airbag is a double stage type.
    b5 one is a single stage type.
    You have to slightly modify the wiring to make it work properly.
    I don't think it would be a good idea!
    Don't joke with airbags.....!!!
    RS4 B5
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    iv got a b6 in my car with the airbag not hooked up
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Jul 07 2004
    VA / DC
    So it can work, but the airbag is not going to function..?
    2001 RS4 Widebody
    2004 R32
    Dapper.
    Veteran Member Four Rings Slave IV's Avatar
    Aug 28 2008
    MkV R32, C5 allroad
    CA
    the old R32 steering wheel is supposed to be a direct fit and the airbag will work...assed out on the other controls i think but the wheel is very nice and thicker than ours...
    Check it out:
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    i just havent tried to hook it up. my luck i'll blow it
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by Slave IV View Post
    Check it out:
    great video... that MRC tuning is pretty serious huh dam!
    Senior Member Three Rings SoEvoL's Avatar
    May 11 2008
    2001.5 S4
    Bama
    I'd go with the R32 setup, the New tt has a hot steering wheel too but its also a DS airbag.
    Keep It Simple
    2001.5 Silver S4 Stg 0.5 or 1-
    Oct 16 2007
    B5 S4 / 335i
    Quote Originally Posted by andream88 View Post
    Correct. Air bag does work. It is set to deploy as a single stage.
    Oct 16 2007
    B5 S4 / 335i
    Check it out:
    Really a VW steering wheel? Who would want to look at a VW symbol while they're driving an Audi?
    Oct 08 2008
    MA
    Quote Originally Posted by AUDILUX View Post
    What modifications are done to the wiring? will this effect safety? what are my chances of blowing the airbag?
    Oct 16 2007
    B5 S4 / 335i
    Quote Originally Posted by wdbdy2000s4 View Post
    I didn't do the install. I can PM you the # of the guy that did the install if you want.
    Oct 08 2008
    MA
    If you could PM me his number that would be great. I can post up the details after I talk to him in case anyone else wants to know.
    Jun 14 2007
    2000 S4
    Connecticut
    1/345,987
    lol you want chances ?!
    Oct 08 2008
    MA
    haha, I just want to know if this is liklely to blow the airbag or not. I'm obviously not looking for a percentage, but if it's very likely I blow it then I'll probly forego the installation.
    Veteran Member Three Rings GetAudiHere's Avatar
    Mar 06 2006
    Minnesota
    yeah let us know! I think it looks hot but not worth no airbag.
    Oct 08 2008
    MA
    I talked to a guy who wired up a Dual Stage A8 airbag on a B5 s4 ( +rep audilux for sending me his info).
    You're going to need the wiring chart for both the b5 airbag and the B7 airbag. Just splice the harnesses from the B7 to the wires from the B5 (there are twice as many wires for the B7 since it's DS and there are 2 harnesses, so the harnesses must be wired in parallel). This essentially makes the dual stage airbag a single stage. I'm assured that this will not blow the airbag, nor will it trip any airbag codes. The actual functionality of the airbag hasn't been tested, however, because no1 really wants to crash an S4 to test if their airbag works. This was done by two audi techs who say they have every reason to suspect it will work though.
    If anyone could post up the wiring diagrams that should help. Don't flame me because I already tried the search.
    Veteran Member Three Rings MeinS4's Avatar
    Dec 28 2006
    Portland, OR
    RS6 is plug and play. No modifications necessary. B6 S4 is fairly easy with harness modification. You need to buy a B5 RS4 airbag harness (available through Audi for $30) and then modify it slightly.
    Jul 20 2004
    MeinS4 I think you helped me when I bought my RS6 wheel (never installed it actually sold it because i was selling the car and at last min decided I searched too long for my noggy and couldnt do it ) but by far your post has to be the most helpful in this thread
    Oct 08 2008
    MA
    any diagrams for a manual b5 s4? I'm looking to hook up the RNS-E nav from a B7 as well to maintain the steering wheel functions. Anyone have a wiring chart for the multifunction wheel?
    Dec 28 2006
    Portland, OR
    You're welcome!!! Also, I'm not positive but the manual B5 S4 just has the yellow connector, no black tiptronic connector. Other than that I think they are the same. The benefit of buying the B5 RS4 Airbag harness is that you don't have to deal with soldering or splicing any connections for the airbag. Just for the horn and I didn't even cut and splice. I just re-pinned the connector. Real easy. If you have a tip, you have to custom make the tip (black connector) harness. But it's easy with the diagram above.
    Oct 08 2008
    MA
    good looks on the airbag info, should be pretty easy to hook up. Anyone have the multifunction wiring diagram? I'm asuming the colors for the multifunction controls will match up to the wires coming out of an RNS-E nav unit. is that correct?
    Veteran Member Three Rings b5s4tt's Avatar
    Mar 14 2007
    s4
    queens
    good info thanks alot
    Active Member Four Rings 00s4slvr's Avatar
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    what about an Rs4 sterring wheel? Can that be done with a Full Fuctioning airbag?
    Oct 16 2007
    B5 S4 / 335i
    Quote Originally Posted by 00s4slvr View Post
    Uh...that's what mine is and that's what we've been talking about...see pics above.
    Veteran Member Four Rings casawhites4's Avatar
    Jan 21 2007
    01.5 Silver Avant
    dc
    are there anymore pictures of people and different steering wheels???
    01.5 Stage 3 Casablanca White S4 (GONE)
    01.5 Stage 0 Silver S4 Avant (New Project, def Grocery Getter)
    watch out Casablanca!!! im coming back with a vengeance!
    Silver will be the fastest now!!! :-D
    Veteran Member Four Rings Klum00's Avatar
    Nov 27 2006
    Baltimore, MD
    was this matt by any chance...?
    Quattro Kings
    @quattroking
    Currently in the garages
    2016 S6 . 2014 RS5 cab . 2013 Q5 . 2008 A6 avant
    2002 TT ALMS . 2001 S4 . 1992 UrS4 . 1974 100 LS
    1952 DKW RT125 . 1939 DKW F8 . 1937 DKW F7
    Oct 08 2008
    MA
    There were two techs. One was named Danek but idk the other one's name. Ironically, I have the phone number of the guy whose name I forgot. BTW, nice thread resurection, it's always nice to see someone who actually looks through the archives/uses search.
    Frimmel: i only speak when i have something negative to say.
    Grah4m: i lost to a giraffe. be careful out there.
    ThirdStrike:leave your feelings at the keyboard
    Jan 21 2007
    01.5 Silver Avant
    dc
    hmm, aaron...what are you looking into doing..im doing what jibberjive has done.
    Oct 08 2008
    MA
    flat bottom euro rs4 wheel FTW!
    Veteran Member Four Rings oneohone's Avatar
    Nov 13 2007
    Baur TC2 / W221 S600
    Dallas, TX
    Check it out:
    Jesus that video is amazing!
    Daily - 00' Audi A4 1.8t Quattro 5mt Laser Red Avant
    In.Progress - 00' A4 2.7t Swap (w/ K04's)
    Jan 21 2007
    01.5 Silver Avant
    dc
    haha. true true. but then what air bag and what not...and thing is, im getting the Sline wheel at a pretty good price. :-D
    Nov 27 2006
    Baltimore, MD
    if i was to do something it would be the flatbottom wheel probably from a new TT. but at $800+ it's not on my to do list at the moment.
    Quattro Kings
    @quattroking
    Oct 08 2008
    MA
    they pop up on ebay for like 600. just wait it out and you'll find one.
    Sep 27 2007
    00 S4 6sp, 06 Mazda3 HB Auto
    Columbia, SC
    I was thinking of putting a ultrasuede over wrap on mine to make it a bit thicker. By wrap I mean stitched in, not the wal-mart type ones.
    00 B5 S4 - K04, Stern Soft MM, Stern Snub, DTS, Neuspeed Rear Sway, Oinkies, GIAC stg 2 XR, Vogtland GT, SSAC copy. Soo... Stg 2.31456?
    06 Mazda3 - Wife's car and autox car
    96 Eclipse GSX - Gone
    03 Acura CL Type S - Gone
    96 Soarer GT - Gone
    93 RX7 R1 - Gone and missing her
