After some searching I am still having an issue tracking down what the problem is. I am suspecting air in my Slave cylinder/lines but i figured i'd ask everyone here.
My shifter is extremely notchy and takes some force to get into any gear. The shifter is aligned properly and i greased up the Linkeage/Joints. Basically when the car is off it shifts into the gears fine. However i have a very hard time getting it into any gear when car is on. Reverse is impossible to get into gear, it just whines and grinds a little. The funny thing is, when the car is off and i put it into gear and THEN turn on the car evern when i press the clutch ALL the way down and try to put it into neutral, it locks me out of putting it into neutral like i dont have the clutch pushed in.
That is what makes me think my slave cylinder is being a prick. Since even when i have it pushed in it's locked out me putting it into neutral.
Also a note, when i have the car off and put it into 1st, then start it the car actually goes forward just ever so slow even with the clutch all the way pushed in, almost like the clutch is just barely touching the PP and moving the car forward... HELP! hehe
oh and the shifter stabilizer bar, how do i tighten the part that bolts to the tranny? i can barely fit up there, i thought it was a socket , but 15mm is too small, and 16 mm is too big, is it allen/Hex? if so, what size
