Results 1 to 31 of 31
Thread: Screaming pipe!
    Senior Member Three Rings a4mafia's Avatar
    Aug 22 2008
    B5 A4 Avant. Ford F250 PSD. Mazda3. Raptor 700r.
    Cincinnati
    Question Screaming pipe!
    okay so my buddy bought an a4 with a screamer pipe on it. i was curious if anyone knew how to install one and what exactly it is?
    Senior Member Three Rings fernando's Avatar
    Mar 06 2008
    01 A4 1.8T, 1998 Volvo S70 T5
    Maple, Onatrio
    Re: Screaming pipe!
    Quote Originally Posted by a4mafia View Post
    if its the same thing that i am thinking of, this screamer pipes is when you have an external wastegate this will act as like a little exhaust pipe for the wastegate dumping out to the atmosphere.....as for intall, you can only get it on GT30's and up....
    GT2871R *Kinetic Motorssports FMIC * VME 4300 HID lights * Turbosmart DV * Revo BT Tune * APR catback exhaust system * custom vent boost gauge * custom vent wideband gauge * zimmerman crossdrilled front rotors with Hawk HPS pads * SB Stage 4 clutch * Neuspeed shortshift kit
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    Re: Screaming pipe!
    wtf is a screamer pipe, isnt it just a dump tube?
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Aug 22 2008
    Cincinnati
    Re: Screaming pipe!
    well i think its a screamer pipe. it has a high whistle when the car is at higher rpm's which would make it full boost which would make it a screamer pipe. hes got a stock turbo
    Active Member Four Rings
    Dec 11 2006
    Boston
    Re: Screaming pipe!
    yeah it is a dump tube. you need to have an external wastegate and have the dump tube not routed back into your downpipe.
    unless he welded off his old internal gate and add a new one, he doesn't have one.
    it isn't a "whistle" sound either...
    Aug 22 2008
    Cincinnati
    Re: Screaming pipe!
    hmm. i wonder. well it sounds exactly like a dump tube. so i couldnt put one on the stock k03?
    Dec 11 2006
    Boston
    Re: Screaming pipe!
    not unless he had an external wastegate.
    k03's are internally gated, as are k04's and several other larger turbos. like i said before, you can take off the old internal wg, weld everything up and add a new external wastegate, but then you have to have a new manifold setup.
    at the end of the day, your buddy doesn't have it. maybe he runs open dumps/exhaust.
    Aug 22 2008
    Cincinnati
    Re: Screaming pipe!
    oh well then im curious at what that noise is lol
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    Re: Screaming pipe!
    he probably got a testpipe. look in his enigne bay and see if theres a cat. either that, or he got chipped, or is running a cone filter instead of the airbox to hear the turbo more. the k03 likes to wistle shes a loud mofo
    Aug 22 2008
    Cincinnati
    Re: Screaming pipe!
    i know more about cars than u think. it has no test pipe. not chipped. has a cone intake but it whistle loud before. maybe it is the turbo. but my turbo diesnt do whistle like his. do u think maybe its because it has 161000 miles on it?
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Re: Screaming pipe!
    Just to clear up an earlier post, you can go open wastegate with a
    T3 tubined 28RS, you do not need a 3076R (aka 30R) and up...
    Jan 25 2006
    A4 2.0T
    MD
    Re: Screaming pipe!
    You can go external wastegate with any turbo, if you feel like wasting your time....
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    Re: Screaming pipe!
    ^^^that link..in your sig. doesn't work?
    whistle sound, you sure its not a sound of the turbo dieing? It does have 161k miles..
    Oct 27 2007
    In the lab
    Re: Screaming pipe!
    Quote Originally Posted by Don Supreme View Post
    Ok ok ok, if you wanna get real ghetto.... But I was saying legitly
    Jan 25 2006
    A4 2.0T
    MD
    Re: Screaming pipe!
    Quote Originally Posted by njm23 View Post
    Its down right now. I will bring it back up later tonight.
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    Re: Screaming pipe!
    maybe he has the bubb rub mod where the exhaust goes whoo whoo
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    Re: Screaming pipe!
    Da Wistle Tip
    Account Terminated Four Rings
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Re: Screaming pipe!
    Woo wooo!
    Senior Member Three Rings a4mafia(Red)'s Avatar
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    Re: Screaming pipe!
    hahaha, its my car....idk what the hell it is, but it sounds sweeeet! thought it was a boost leak for awhile but guages say differently
    work in progress....
    B5 A4 2.8 FWD Transmission:
    http://www.audizine.com/classifieds/...ct=9554&cat=12
    Established Member Two Rings Accel's Avatar
    Jan 30 2008
    Vancouver
    Re: Screaming pipe!
    Maybe your turbo's about to go.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: Screaming pipe!
    Sounds to me like a blown turbo!!! haha
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings JumboBlack1.8's Avatar
    Sep 16 2006
    '98 528i
    Boston/West Hartford, CT
    Re: Screaming pipe!
    Quote Originally Posted by Accel View Post
    sounds about right
    Edit: Hopefully it doesn't sound like this
    http://www.youtube.com/watch?v=1aiNA...eature=related
    2000 Audi B5 S6 ** 4.2L 40v S6 6spd - http://www.audizine.com/forum/showth...n-s6-4-2L-swap
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    Re: Screaming pipe!
    Quote Originally Posted by 317ssayzarc View Post
    Actually you can do it with a T25 2860rs as well
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    Re: Screaming pipe!
    its not blown. thats obvious, i dont think its about to blow either, my guess is shaft play....i'll try and get a vid of the sound sometime soon
    Sep 16 2006
    '98 528i
    Re: Screaming pipe!
    Quote Originally Posted by a4mafia(Red) View Post
    Shaft play means the turbo is about to blow, if it hasn't already.....you may still be producing boost, but eventually the turbine wheel will completely lose its balance.....the turbo really shouldn't be "screaming," or making any other unorthodox noises if its a healthy turbo. The turbo will produce boost until its totally out of balance, but the more u beat on it, the worse is gets (happened to me with my POS GT2871r that I had bought used...)
    do u have any white smoke coming out of ur exhaust? Thats another sign to look out for....thats a result of a bad oil seal that occurs when or right before a turbo goes
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    Re: Screaming pipe!
    no oil....the reason i say i dont think the turbo is about to go is bc its been doing this the whole time i've had the car in my possesion and i race and push it HARRRRDD sometimes. and i've had the car for the last 25000 miles. so has it been about to blow for the last 25000 miles?!?!?! also it fits somewhat the description of a screamer, it sounds when i'm at full boost, when i got my 3" piping it sounded sooner and also the turbo spooled quicker...somewhere online i read that stock b5 a4/s4's may come with screamers
    Registered Member Three Rings Rhinop21's Avatar
    Mar 04 2008
    West linn, Oregon
    Re: Screaming pipe!
    Vids! Wtf is a screamer pipe lol.
    http://i200.photobucket.com/albums/a.../dopeaudi3.jpg
    1998 A4 sold
    1995 Talon tsi awd. 6 bolt swap.
    Veteran Member Four Rings Euro-Tuner's Avatar
    Jan 06 2007
    NH
    Re: Screaming pipe!
    street race or track?
    ...your running a stage 5 SB clutch on a stock engine?
    Mar 04 2008
    West linn, Oregon
    Re: Screaming pipe!
    Damn if I had a stg 5 id do 6.5k dumps everytime i accelerated.
    1998 A4 sold
    Nov 06 2008
    B5 A4 1.8tqm
    Cincinnati
    Re: Screaming pipe!
    not track race....haha yes stage 5 on stock engine...
    i dont go up to 6.5k bc then when i shift i'm already half way through my boost in 2nd...ha but ya i go up to like 6k-6.2k(stock clutch cant handle that....found out the hard way)
