Brought my A4 (2006, 30k miles) in for service yesterday (gasket on coolant line coming into engine apparently defective, caused massive leak, etc) and asked if they could check out the fact that my brakes squeal like crazy.
I was told that the pads are almost in need of replacement and that the rotors were lipped on both the inside and outside and would need replacing. They quoted me a price of around $550 to replace both of them. They also said front tires were pretty worn and that I should replace them, along with balance all tires and do an alignment, brining the total up to just over $1000.
Now, as much as I love having people do the work for me, these days, the more money I can save the better. I have my own lift, have a complete set tools, and am more then happy to buy a new pair of pads and rotors and change them myself.
My question is - for some with extensive experience with car repair, how hard is it to replace rotors and pads on an A4? I know on the new A6's, you need some kind of computer to release the electronic e-brakes, making it impossible to do rotors yourself. Is this the case with A4? What are some good suggestions for rotors and pads? Where should I get them from? I was thinking just buying a set of Brembo rotors for the front as they really can't be too much more then OEM, plus they'd probably last over 30k miles. Should I just get the rotors cut instead of replaced?
Any help is appreciated.
