Results 1 to 11 of 11
    Veteran Member Four Rings mdzaudi's Avatar
    Jul 30 2008
    '03 A4 1.8tqm, 91 Explorer, '05 Arctic Cat M6
    Downtown Denver, CO
    When it Rains it Pours
    Problem free car for 2 years prior to this month other than an ignition switch.
    Well i've been talking with shops to get my clutch replaced for the last three weeks and hell started to rain down on me two more times.
    I noticed slight vibration and noise while driving and it's been diagnosed as proabably a wheel bearing or CV.
    Yesterday i got the first CEL since i've had the car. The car started to vibrate while idling as well as while driving and there was a significant loss of power. My first thought was coilpack but i'd like to hear anyone elses thoughts.
    -Matt
    FCDT Member #1
    Veteran Member Three Rings PCYC's Avatar
    Sep 07 2007
    04 A4 3.0 6spd, 06 A6
    Atlanta GA
    Re: When it Rains it Pours
    Sucks whats your ODO read?
    Buncha motorcycles
    Memphis, TN
    get the fault code and it should narrow it down for us pretty quick
    APR Stage 2/AWE Intake
    Oct 15 2006
    From a few to one...
    Arlington, VA
    is the CEL flashing?
    either a boost leak or a coilpack...
    open up ur hood...while the motor is running, unplug each cp...if the idle gets worse, its a good pack. if the idle is unchanged, its a bad one that needs to be replaced....
    if all of them are good, start looking for boost leaks...
    btw, test out the cp's when ur engine is cold...otherwise you'll be sorry...
    '97 A4 1.8TQ, '02 A4 1.8TQ Avant, '03 A4 1.8TQMS, '04 A4 3.0Q Cabrio - Sold
    '18 S4 Prestige - Kohlefaser Luft-Technik Intake
    Jul 30 2008
    Downtown Denver, CO
    Yeah it's a flashing CEL so i'll check the coilpacks tonight. Haven't check for codes yet as i don't have a vag-com.
    -Matt
    FCDT Member #1
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    I can check it out today for you.
    Jul 30 2008
    Downtown Denver, CO
    Yeah Jordan, give me a call, i get off work at 4:30.
    -Matt
    FCDT Member #1
    Oct 15 2006
    Arlington, VA
    flashing cel is more than likely coil packs. check those out and we'll see what's up.
    Senior Member Three Rings jonsaudi's Avatar
    Jan 09 2008
    2003 A4 1.8T tip quattro
    California
    Yeah I'd like to know if it turns out to be wheel bearing or CV. Btw, the noise it makes, does it sound like grinding or humming noise when your cruising??
    • 03 A4 B6 1.8T • Tiptronic • Brilliant Black • quattro • Sport Pkg //18" RS4 style rims //35% tint //Zimmermann x-drilled //Hawk HPS //CF wrapped trim.
    Veteran Member Four Rings a4wd's Avatar
    Jul 27 2004
    B6 1.8TQM 5speeeeeeeed
    Bay Area 925
    Quote Originally Posted by jonsaudi View Post
    When my wheel bearing was out, I would hear a grinding squeak type of noise. My mechanic said a good way to see if its the wheel bearing is if your car doesnt make that noise during braking, it could be a huge sign that the bearing is out. Hope that helps!!
    another stereotypical Audi
    Jul 30 2008
    Downtown Denver, CO
    Checked the coil packs and sure enough one looks to be out so i'm fixing that tomor. Hard to explain the sound that the cv or wheel bearing is making. I'll let you know what it ends up being.
    -Matt
    FCDT Member #1
